Aerial Photography and Video Discuss the growing field of aerial photography and aerial video right here!
COAX
Reply
Old 12-28-2003, 08:22 PM
Crash Pilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default COAX
Hello
Just in the process of trying to build my first video down link for my R/C Heli.
I have purchased the kx 121 from B/W and at present have the ebay 800mw TX system.
I will probably be changing the TX with the B/W system before I have this project in the air.
Is it better to run the video cable from the camera to the TX in coax or just your standard RCA cable to reduce noise interferance?
The coax that I have used has the copper braded shield around it and is about 300mm in length. I have covered the camera enclosure with aluminum tape and grounded it to the camera grounding point.
The camera picture is fine but not sure if the coax will reduce the transmission range.
Any help or suggestions would be appreciated.
Crash Pilot is offline
Old 12-28-2003, 11:22 PM
mr.rc-cam
mr.rc-cam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: COAX
The simple shielded cable found in a typical A/V cable will work fine for nearly all R/C wireless video installations. It is generally not required to use coax cable if you keep the lengths short. However, if you do use coax and want it to be effective, then use RG-179 or similar 75 ohm type.
mr.rc-cam is offline
Old 12-29-2003, 04:15 PM
Crash Pilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: COAX
Thanks for your reply.
