Found a great source for SMA pigtails!
FL
I needed a shorter pigtail from the 1 watt transmitter to the externally mounted
dipole-in-a-duck, the one I was using was about 32 inches, the path was only comfortably 18 inches, I know the loss wasnt gonna be much, but why route the cable around when you can go a direct route?
I found L-COM in Andover, Mass. their prices are pretty good, cheaper the more
you buy. I only bought two 18 inch SMA RG174 pigtails (one as a backup) for $16.25 each. I didnt think it too bad, Ive priced just SMA adapters to other connectors and panel/chassis SMAs for $5 a piece!
Anyway, shipping was $7.95 Fedex Ground
Heres the link:
http://www.l-com.com/jump.jsp?lGen=p...&iProductID=36
Thought Id pass it along.
Heres the link:
RE: Found a great source for SMA pigtails!
Thanks!
That is just what I am looking for as I want to do the same external antenna setup you did. Just gotta remount the tx and figure out what length I need. Fav placed the site so I can find it again. I just received a 900mhz patch antenna I won on Ebay so now I need to get off my butt and revamp the KSA.
Thanks again!
Thanks again!
ORIGINAL: KE4UVQ
Heres the link:
Heres the link:
