5v battery eliminator...
Any suggestions on a switched mode battery eliminator for a 5v video system? I had an s-bec from firmtronics, but it stopped working today (for no good reason...). I generally run 8.4-9.6v and am looking for an efficient isolated switched power supply to give me 5v at 500ma or so.
Steve
Steve
RE: 5v battery eliminator...
I think those are linear regulators. I really want the isolation and efficiency of a switched-mode converter. Thanks.
Steve
Steve
CA
You might want to checkout the TI/PowerTrends switchers that Digi-Key stocks. They come in a variety of I/O voltages and current ratings. They also have friendly form factors.
Thanks. I just ordered one. I tried using a linear regulator, but the noise from the pulses hitting the motor always gets through to the video signal. The s-bec worked for a while (firmtronics), hopefully the u-bec will last longer!
Steve
Steve
CO,
That's weird about the Sbec giving out... I use one on the servos of my helicopter, hope it doesn't give out while I'm in the air!
Bill
Bill
I should probalby contact them. It would probably be out of warrenty but it's worth asking. It just quit, very strange. Remember my problem with auto-iris? One of the surface mount caps on the camera came loose. I tacked in a replacement last night and solved the problem. Man those SMD parts are tough to work with without the right equipment!
Steve
Steve
