Amature aerial photos from my Aerobird
I'm getting a bit better at this aerial stuff, but am still having to take stills from the 2 min of
video I can get from my Aiptek. Would like to get the Cam Man project done, but am afraid
I'll probably botch it. I wonder what the best way would be to get a servo to trigger the camera
instead? Hmm...
instead? Hmm...
RE: Amature aerial photos from my Aerobird
Well, I think this is about the max you would want to put on the Aerobird. I put the Aiptek mini pen cam with two AAA batteries and
it flies, but take off is sluggish. It would be better if I finished the "Cam Man" project, but I'm not sure if I'll ever get around to it. Would rather someone else do it and I just pay for it
Thank you! I'm surprised how high I've taken it. My first Aerobird was defective, but I sent it back and they replaced it
with a brand new one. Not sure how high I had it up? The real challenge will be getting the Cam Man project done... if I dare.
ha ha... yes, it is Branson behind Wal-Mart. Believe it or not there is a pretty nice area to fly behind wally world. I'm tempted to take
the Aerobird up even higher, but wonder if I'll lose it. I wonder if anyone makes any glasses that you could put on that would magnify your viewing area by about 2x so you could see what direction your plane is going?
I have seen a set of binos on a bracket around your neck type deal,so you could look back and fourth hands free.Nice pics
I have a wireless tiny camera from EBay with receiver on the ground, Aerobird handles the same, no lack of performance at all, including the camera and a 9v battery!
Here's a snippet of the aerial video...
http://www.a-hall.com/_temp/rc/Final..._processed.avi
SC
Nice job, Manatee and Ashleyhall! I wouldn't want to look towards the sun with those 2x glasses on- Your po' retinas would feel like an ant beseiged by the Magnifying Glass from Hades!
What remains to be done on your camman system? I've found that 'getting in the mood to start' is the biggest challenge sometimes... everything else is easy.
Try replacing the 9V battery with a pair of small lithium poly cells- like a 340 ma or so. Only 7.4 V instead of 9V but the duration would be 30 minutes or more. Another option is to parallel another 9 v to the power sytem if you can haul that much more iron aloft. Same voltage, twice the capacity.
Good luck, purdy pix.
Ahhh, you'll need the XVID codec, there's an EXE in the same directory, grab that and you'll be fine (remove the filename from the filepath to view the rest of the files in the directory.)
It worked! Thanks... great video! How much did you pay for the camera and do you know what I would search for the get one myself?
Hey dude,
Thanks! Thats just a tiny clip from a 5 minute video, would post the rest on there but they're rather large!!
Took the video via a wireless camera from EBay, search for exactly 'Wireless Camera', however don't pay more than £30 for one (including shipping), and beware of those shipping them from Hong Kong, you want one thats sourced from the UK straight to you.
A lot of them also put them on for only £20, but load it with a £24 shipping fee!! Beware of these too!
Good luck mate, post your findings here and I'll let you know whether or not its worth bidding! Also 2.4ghz is preferable to 1.2ghz as its longer range, you'll need between 200m-500m range, nothing less (as some of the wireless cams on there are only 40m!!)
I went looking on that webpage you gave out. How does this exactly work. I mean I see the camera and mount it somewhere but how is the video saved or transfered and the power source. Is it on constantly or by servo? Thanks,
Hi there,
Basically, you hook a 9v to the camera, it then constantly sends a video feed to a receiver thats powered by 12v battery, I've made up a lead to power it via my car battery.
The Receiver's got Video out, I thought the best way to record was directly into my laptop, so £40 later I bought a USB2 Video Input cable for my laptop, plugged the receiver direct into that, and was able to use a Video editing application to record the feed in whatever format I wanted!!
Personally, I think thats the best way, no tapes, no DV cam to worry about, its just there straight away to watch after!!
Hope this helps!
Hope this helps!
So the camera is in the plane with a 9volt and the reciever is sitting in your car with the cigarette lighter reciever the data from the flying plane?, then you go home and hook the receiver up to your computer? Sound right?
Nooooooo!!! The receiver is plugged in onsite and powered up, it is then connected to my laptop which IN REAL TIME records the flight, so at one point during recording my last aerial video, I actually flew the plane FROM THE LAPTOP SCREEN!! It was amazing, kind of like the best flight simulator EVER!
VA
ORIGINAL: ashleyhall
Here's my vids...
http://www.zwei.net/video/Sailing-030204-1.zip
http://www.zwei.net/video/Sailing-030204-2.zip
http://www.zwei.net/video/NovaCC_Par...t_Flip.avi.zip
I'm sure I'll have more ariel things when I invest in the new cam system.
--Scott Fuller
VA
ORIGINAL: Cyclic Hardover
I slowly "getting it" here but now let me ask this because this is how things are for me. I don't have a laptop. Can this be done at the field, recorded and brought home and hooked up or is a laptop needed?
--Scott
MO
I am preparing to fit my aerobird challenger with video capabilities. I have seen a lot on here about the equipment that you all have used. It seems like the cheapest and most simple is to use a pen camera, but i want to get more than 2 minutes of video. Is there a fairly decent wireless camera that anyone can recommend to me. I cant seem to find one that runs in 2.4ghz and has decent range. Thanks
I personally bought a transmitter/receiver and camera set from EBay, cost around £30, I then stream the content straight onto my laptop and record as an AVI, allowing unlimited video!
Works very well, here's a clip!
You might need the XVID codec to play this...
http://www.a-hall.com/_temp/rc/XVID%...y%20Videos.exe
