Infrared Pictures
My Feedback: (36)
Infrared Pictures
I have a very inexpensive digital camera that I removed the case of for use on my Slow Stick. The pictures it takes are great but I would like IR pictures. I know the detector will view IR light because when I point a remote at it and push a putton you can see it flashing. I want to know if it is possible to change the threshold to only detect IR or install a visible light opaque filter an increase the exposure. Any advise would be great.
CA
RE: Infrared Pictures
You can remove the IR filter from the lens to increase the amount of IR light that is detected. However, the results will not be the same as a true IR Thermal camera. For that, you need to spend a LOT more.
RC-CAM
RC-CAM
CO,
Once you get the IR filter removed, you mentioned a desire to filter visible light. You can purchase a visible light filter from a photo shop, I got mine from B&H photo.
these filters are pricey (the 'cheap' one is around $13) so one thing you can use as a poor man's visible light filter is a completely exposed piece of 35mm negative. Your local photo shop should have snippets of these laying around that they can give you. Generally these will be the film leaders that get cut-off as they cut the negatives for packaging. It will look completely opaque to your eye, but it will pass a surprising amount of IR light.
Regards,
Bill
Regards,
Bill
ND
Where is the IR filter? I can post pics of the camera if nesasary.
probably right in front of the CCD/CMOS or even integrated into the imaging assembly. it won't look like much, completely clear to visible light so don't expect to see anything that stands out. i don't know if any cameras use it, but it is entirely possible to add an ir blocking covering to one of the lenses itself, making removing it pretty much impossible...
CA
http://www.rcgroups.com/forums/showthread.php?t=138233
RC-CAM
My Feedback: (36)
Wow, that's a great link! Thanks. Question though - When you say a complely exposed piece of negative, would that be exposed and developed or just exposed? Could I buy a roll of film at the dollar store (at like 2 for a dollar) and use that or do I need to take a roll, pull the film out, hold it up to the sun and then develop it?
Thanks everyone!
Thanks everyone!
CO,
Sorry... Exposed AND developed.
That's why I suggested heading down to your local photo processor, they should be able to just give you a piece of exposed and developed film.
Regards,
Bill
Regards,
Bill
