Aerial Photography and Video Discuss the growing field of aerial photography and aerial video right here!
camera mounting question
Old 03-30-2005, 02:00 AM
nexstar22
Default camera mounting question
I was wondering if my nexstar could handle the weight of a sony handycam. I was thinking about this cause I would like to just press record and fly. its alot easyer that way.
Old 03-30-2005, 12:05 PM
randall1959
randall1959's Avatar
Default RE: camera mounting question
If you want to just hit "record" and fly, the two best cameras I know of that would fit your plane would be either the Mustek DV 4000 or the Nikon 3700.
Old 03-30-2005, 08:28 PM
roltech
I don't know what your handycam weight, and what size motor on that nextstar, you will have to get the CG and add or shift the weight around to balance the plane or you could loose plane and cam. Some may modify the cam batteries to a lighter set just for flights, depending what type batteries the cam takes, some of them are heavy, and you want to keep it as light as possible.
roltech
Old 03-30-2005, 10:17 PM
nexstar22
thanks for the help. I hope to get some videos made sometime in the near future!!!.
Old 03-30-2005, 11:00 PM
roltech
Here is someone that has recorded some video with handy cam off some sort in the plane cockpit and did a very good job
roltech.
http://www.rcuniverse.com/forum/fb.asp?m=2823751
Old 03-30-2005, 11:15 PM
randall1959
Actually that's a digital camera a lot like the Nikon 3700
