Need tiny passive ir capable cam for tank
Need a wireless cam smaller than 1"x1" that will work well at night. Something like this http://www.raidentech.com/miwispycanca.html that works. I'm needing it for an rc tank to use in conjuction with a non visible ir targeting laser for night fighting.
RE: Need tiny passive ir capable cam for tank
i put one on my rc tank that shoots bb's. I mounted it right on the barrel. It's awesome, i drive around my house using the tv to see what I'm shooting at.
What will work best for you is a low lux Black and White camera. Like this one.
http://www.supercircuits.com/index.a...OD&ProdID=4221
Check their site for other specs though. They have a lot of options. The lower the lux rating, the better it will see in darkness. Since there isn't enough light in the dark to reflect color, a color camera would work against your system. They don't have the same resolution for size and don't typically see in as much darkness. (Higher lux ratings)
Dan
Dan
