Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > Aerial Photography and Video
Reload this Page >
Flying two totally different planes with one wing.
Aerial Photography and Video Discuss the growing field of aerial photography and aerial video right here!
Old 01-08-2006, 12:34 PM
randall1959
randall1959's Avatar
Default Flying two totally different planes with one wing.
I got to thinking how similar my Easy Star wing was to the wing I had on my WASP and decided to do some experimenting. All I had to do was drill one small hole in the center of the ES wing to bolt it on. It's held on with a pvc strap and balances just right without any further mods. I flew it yesterday for the first time and was impressed enough that I came home and did a little more tweeking but I haven't flown it yet. I had to paint the wing red with testors but I like the way it looks on the Easy Star also. It sure makes it a lot easier to see against a cloud. Here are two videos I did yesterday also. The first one is with my Head Cam so you can see how it flies and the second one is on board video using the same plane and wing.
http://www.skidrow-aerodrome.com/Hea...ASP%20Star.ASF
http://www.skidrow-aerodrome.com/Duncan%20Park.wmv
ID:	383490   Click image for larger version
ID:	383491   Click image for larger version
ID:	383492   Click image for larger version
Old 01-08-2006, 12:42 PM
Tall Paul
Default RE: Flying two totally different planes with one wing.
Totally different like this?:.....
Old 01-09-2006, 11:21 PM
Fred420
Fred420's Avatar
OK ....what plane is that?
Fred
Old 01-10-2006, 01:35 PM
Tall Paul
ORIGINAL: Fred420
Fred
the normal looking one ... Wing was a combination of Clark-Y and S3021.
AstroFlight 05 geared, and
Speed 600 geared motor, 13x10 prop, 8x1400 Nicads
Pod plane.. same wing and power.
The normal plane outclimbed the pod plane the day I flew the wing on both of them.
The wing needed more dihedral, so I extended the tips 9 inches on each side, and tippet them up, after some flying.. to improve the lateral response with the rudder.
The pod plane carried two Aiptek 1.3M cameras arranged to shoot just off the center of the flight path with about a 5 degree overlap at the center to give a wide-angle coverage.
The normal plane had the camera outside at first, then inside looking straight down.
ID:	384910   Click image for larger version
ID:	384911   Click image for larger version
ID:	384912   Click image for larger version
ID:	384913   Click image for larger version
