question about monitors
I use a mini cam in conjuction with a mirror periscope in my rc tank. Problem is the video image is reversed due to the mirror. My question is, are there any high speed monitors out there that will alow me to reverse the image ?
AL
RE: question about monitors
Another mirror in front of the monitor .... ?
If you just need an unreversed image to drive the tank around with, then try another mirror at the monitor. Of course, that's a quick answer if you are watching the video live but obviously your recorded video (if that's what you're doing) will still be backwards.
You could do some heavy video editing to reverse the video. I believe Adobe Premiere has a feature to reverse the affects of a mirror image.
Good Luck,
d.tipton
Good Luck,
d.tipton
GA
Yes, there are LCD monitors that have a pos/neg switch for doing this because they are sometimes used as teleprompter monitor which use a mirror. Make sure to ask before buying though. You can get these at the links below. They run between $200-$300. And yes, software like Adobe Premiere will allow you to flip the image and much more.
[link=http://www.bhphotovideo.com/bnh/controller/home?O=productlist&A=details&Q=&sku=184143&is=REG&addedTroughType=search]B&H Video[/link]
[link=http://www.varizoom.com]Varizoom[/link]
www.markertek.com
www.markertek.com
