2 video helicopters & 4x4 Rock Crawlin'
GA
RE: 2 video helicopters & 4x4 Rock Crawlin'
That was very cool! [sm=thumbup.gif] What kind of helos are those and are they gas or electric? Also, what kind of cameras were used and was it on-board or downlink recording? Thanks! I'm assuming that you have a special landing platform because of that gear hanging so low underneath. I am going to do some air to air soon but with a camera jib. I won't have as much versatility as you did and can only go 25 ft high with this arm but I can get those overhead and booming up/down shots with my remote head and if you weren't told, you wouldn't know it was a jib.
MD
Sky High: Check this out: http://helicamsolutions.com/ Really cool stuff!
Both those mounts are HeliCamSolutions Mark IV mounts and were shot from Gas (gasoline) helicopters like my Condor . IMO downlinks are ONLY good for seeing what the cameras sees. We are years away for wireless HD. I think they were 3 CCD Canons not sure there.
GA
Thanks for that link Twinturbostang, very interesting. [sm=thumbup.gif]
I totally agree and always prefer onboard recording but for some of the smaller helos like mine a pound of gear is not an option. In my industry any camera that is used for framing only is known as video assist.
Wireless HD maybe, but HD and HDV (mini DV HD) cameras were recently released back in December with cameras like the new Canon XLH1, Panasonic HVX200 (records DVC Pro 25/50 and true HD on P2 flash cards!) both of these support true HD as well but in different ways, and finally the Sony Z1. You can find more info about these an many other systems at these links.
HDV Forum
www.dvinfo.net/conf/forumdisplay.php?f=61
www.dvinfo.net/conf
ORIGINAL: DebianDog
ORIGINAL: DebianDog
HDV Forum
www.dvinfo.net/conf
ORIGINAL: DebianDog
[/quote]
WIRELESS HD not lightweight HD I will probably pick up an Sony HC1 this year. I keep up with stuff. I run the iMovie FAQ and have been editing with Final Cut using a Sony VX-2000 for years. I had to order a special mount to get my VX-2000 to fit on my Helicopter.
You need a bigger helicopter. Ion or Joker if you insist on electric. [8D]
Also for TRUE HD you would have to run it out of an HD-SDI connector as (you probably know) HDV has MPEG2 compression. There is not a flash card big enough to hold much uncompress HD.
GA
ORIGINAL: DebianDog
ORIGINAL: DebianDog
Well "all up weight" is the issue. My mount weights 5.5 lbs (I have a gryo stabilized Broadcast 360) and the camera plus battery is about 4.5 lbs. I still have to add a downlink and associated equipment (soon hopefully) but I am already at the limits of what "most electrics" can do. However that is NOT to say that an electric could not do it. If I had unlimited money I would figure out a solution using a Joker or Ion. Once you add in the batteries a large electric is AT LEAST twice as expensive to do. even if you already own the chargers. And... you will never get 20+ minute flight times like I do with my gasser.
Joker base kit or Ion-X base kit both top quality machines.
I (personally) think the best deal going right now is the Century Condor. I have to upgrade to the heavy duty clutch to have a "real" Condor (as I bought and assembled all the parts before the lit was ready as a kit) and lifting 15+ lbs is not a problem although I have only tested 10 lbs. It was effortless with 830mm blades.
Buy the helicopter first if you gonna blow $1700. I would take it over a card[sm=bananahead.gif]
The Pansonic HVX200 will record up to around 45 minutes of the broadcast quality SD video on the P2 flash cards but only around 8-10 minutes of true HD. Those cards are around $1700 apiece too.
GA
ORIGINAL: DebianDog
Well "all up weight" is the issue. My mount weights 5.5 lbs. I have a gryo stabilized Broadcast 360 and the camera plus battery is about 4.5 lbs.
I actually found those 8 Gb P2 cards for $1400 apiece and the half capacity 4 Gb version, well, $650. The only real advantage of those cards or any cards is no load time into an NLE. You have to get the camera first which is only $6000.
Did you see my other post about the Firestore DTE? It weighs less than a pound and can record up to 6 hours of uncompressed DV video!
DTE Info
www.rcuniverse.com/forum/fb.asp?m=3877448
GA
This company seems to have already seen the potential of making these micro gyrostabilized heads.
UAV Camera Heads
www.remotei.com/products_cammount.html
www.remotei.com/ri250.html
www.remotei.com
This video does show some type of heading lock being demonstrated.
http://www.remoteilabs.com/movie/Rem..._BoschAero.wmv
UAV Camera Heads
www.remotei.com
I special ordered my mount from Jodie, it is gyroscopically stabilized on the tilt access using a 401 (see attached)
I have seen the DV hard drives... a year or so back http://danslagle.com/blog/?p=104
Still to money $$$ for little old me. I have better places to spend my money.
Oh he is another video he did and you can see HIS stabilization system using 401's
The new Mark IV from HCS - Test Flight 1 - 27.8 megs - WMV format
GA
Yes, another great video but this time I was even more impressed with the ability of that pilot and helo to produce video in enough wind to stand that flag straight out at 90 degrees! Now that's impressive. How much wind would you say that was, at least 15-20 mph?
