Black Box V2 & GPS....input please.
AB, CANADA
As I have mentioned, Act-Labs has been working on the development of a new version including GPS OSD. I have a few questions to throw out for consideration and comments are encouraged
OK, with having GPS on screen display, what would your purpose for it be?
Is just having the GPS info displayed enough or would it be good to have the info recorded internally for play back later to see "where you went?"
What if this went further and not only did the BB V2 have OSC GPS but the BB had GPS pass through ability so it could be linked to Matt K's PDC-10 clone for autonomous flight? Does this make your imagination turn up a notch?
Please post your thoughts, ideas or email them directly to me
Mike
PS: My pusher is very close to its maiden!
Mike
RE: Black Box V2 & GPS....input please.
I would like an OSD that runs on 5 volts. I would like to be able to have the altitude converted to feet.
Also, I want the Lat and Lon expressed as degrees and decimal minutes as well as heading and speed.
The pass through isn't likely needed as a design crtieria. I currently feed my GPS output via a Y cable to
my PDC-10 and my OSD unit. The RS232 format will happily drive several devices. This is better I think
as it runs the units in parallel instead of series.
Dan
Dan
