Aerial Photography and Video Discuss the growing field of aerial photography and aerial video right here!
Which Microphones do you use ???
Old 10-07-2006, 10:06 PM
JettPilot
JettPilot's Avatar
Default Which Microphones do you use ???
I am having trouble finding a good, small line level microphone for the BWAV video transmitter. I am presently using a mic from supercircuits, its small, but its way to sensitive, even wrapped in plastic and tape it drives my audio to distortion [:@]. Anyone here know of a good mic that is the correct level for the 2.4 transmitters ?
JettPilot
Old 10-08-2006, 03:48 PM
Marro
Default RE: Which Microphones do you use ???
I had the same problem. I got the high-gain mic from the supercircuits by mistake and the darn thing was so sensitive that was clipping the sound when the motor was on. I ended up cutting the shrink-wrapping, soldering a 1k trim pot ($1) in parallel to the mic and re-shrink wrapping the board. Now I have a variable gain mic that works great .
Hope this helps,
Miro
Old 10-08-2006, 05:33 PM
JettPilot
JettPilot's Avatar
That sounds like a great fix, I will do it Where did you get the trim pot ??
JettPilot
Old 10-08-2006, 08:50 PM
Marro
Got mine at Fry's Electronics here in Bay Area, but I'm sure you can get it at local Radio Shack. Just make sure you mount it as close to the mic (as short wires as possible), or use shielded wire because of the high gain the wires will act as antennas.
Miro
Old 10-09-2006, 01:55 AM
typicalaimster
typicalaimster's Avatar
Super Circuits used to sell them. I don't see them listed on thier web site anymore. I'll see if I can dig up another source.
Old 10-10-2006, 03:16 AM
lvspark
lvspark's Avatar
I used this one with a 600mw lawmate module..
http://www.radioshack.com/product/in...entPage=search
Old 10-10-2006, 11:41 AM
steve_molmer
steve_molmer's Avatar
Jetttpilot:
The are many ways to help reduce the clipping.
The best way I have found to solve the problem of distortion in any omni-directional microphone element is to attenuate the frequency response.
All you need to do is to putt a 10k ohm pot is series with the output of the mic broad it self. adjust it till the clipping is removed. (with the engine running.)
Always mount the mic in the plane using foam and cover the mic cartridge with a wind cover to lower the back ground noise.
Never hard mount the mic with-out using foam around or on the mic mount.
I think you will find that you are over driving the amp on the transmitter and not the pre-amp on the mic board.
Let me know if this helps
cheers
Old 10-10-2006, 07:42 PM
JettPilot
JettPilot's Avatar
Thanks, the microphone is wrapped in plastic and tape, and it so sensitive that it still overdrives even on the ground with the engine at idle [X(] I will try the resistor in series with the output, but I would like to use a fixed resistor. Given this, what value of resistor would you start with ?
JettPilot
Old 10-11-2006, 12:11 PM
Marro
Pardon my ignorance, but how does the reisistor in series on the output attenuates the freq. response??? If anything, it changes the impedence of the system to the point where the two are no longer in balance.
Miro
Old 10-11-2006, 01:04 PM
lvspark
lvspark's Avatar
Insertng a resistor in series with the audio signal will lower the voltage of the audio signal to the av/tx's audio in.
I have no idea what this will do to the impedence, but I have done things like this in the past and it seems to work good enough.
Chewing gum works pretty good too!
Old 10-12-2006, 01:39 AM
JettPilot
JettPilot's Avatar
If I change the impedence, then the sound quality might not be perfect. And we all want to hear that gas engine and wind as if we were actually in the plane But given no other practical solution, I bought a bunch of resistors today and will find the one that brings the sound to a usable level.
JettPilot
Old 10-12-2006, 11:38 AM
Marro
I *think* I use about 500ohm (0.5k) in parallel to the mic. I could be off by 100ohm
Here's the video taken with this mic:
[link=http://video.google.com/videoplay?docid=4128587115946162367]video[/link]
Miro
Old 10-12-2006, 10:37 PM
JettPilot
JettPilot's Avatar
Cool video, good sound, and lots of landing practice
JettPilot
Old 10-12-2006, 11:01 PM
Marro
Heh, thanks ! The plane was too small and way too heavy for the setup it was carying... I know, excuses, excuses I've just ordered an EasyStar that I can put all that stuff on, including pan/tilt camera.
Miro
Old 10-15-2006, 11:12 AM
steve_molmer
Jettpilot:
I have found that a 6.5 k ohm is a good starting place.
