Battery pack for camera
OH
Looking for some advice. I have a small board camera that requires a small AC plug-in adapter. I would like to power the camera with the optimal battery pack (small size and long life). I am just a simple geologist so I'm not too confident in what I am doing. Desperately trying to avoid burning up the camera with an incorrect power supply. Pics are attached. Can someone recommend a battery pack and procedure for getting this thing running without an AC adapter?
ON, CANADA
RE: Battery pack for camera
Well, the one thing you should be really careful about is the polarity. If you plan to modify the cable connections, please pay extra attention to the polarity. Make sure you connect the red wire to the positive lead of the battery and the black cable to the negative. The yellow cable (or possibly white) indicates the video signal. Make sure that is clean and doeas not touch the other two. Usng a 3 cell lipo (11.1V) battery will not burn the camera down, only if you reverse the polarity. You can also probably use a vide variety of other batteries, just make sure the votage is not more than 12V and not less than 9.5V. The AMP of the battery doesn't matter, because the camera will only draw as much power as it needs. There are small 3 cell batteries wiht 500-600-800mAh, which should give you plenty time of opertation.
