Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > Aerial Photography and Video
Reload this Page >
FlyCamOne2 cold temperature solution
Aerial Photography and Video Discuss the growing field of aerial photography and aerial video right here!
Old 02-18-2008, 05:25 PM
barryp
Default FlyCamOne2 cold temperature solution
Here is a solution to cold temperature problems with the FlyCamOne2. Use the Rx batteries (glow-gas power) or power from your ESC-BEC (electric power) to power the FlyCamOne2. A simple tap made from two servo extensions will bring power to the FlyCamOne2 base. See the wiring diagram and photos. Pay close attention the the polarity reversal mentioned in the attached wiring diagram. Unplug the tap from the camera when not in use to avoid possible electrical leakage to the Rx circuit.
I've had 15 minute in flight videos at temperatures of -2C (28F)
http://www.youtube.com/watch?v=e-UALENHBOI
ID:	882560   Click image for larger version
ID:	882561   Click image for larger version
ID:	882562   Click image for larger version
ID:	882563   Click image for larger version
ID:	882564   Click image for larger version
Old 02-18-2008, 06:25 PM
SON OF PALEFACE
SON OF PALEFACE's Avatar
Default RE: FlyCamOne2 cold temperature solution
Nothing like some 'grass' in your 'glass'
Old 02-23-2008, 01:29 PM
TruBlu02
TruBlu02's Avatar
Great Idea! Quick question though. In your wiring diagram why is the harness you made going to the throttle channel? Can't you just tap into the battery lead going to your switch?
Old 02-23-2008, 02:05 PM
barryp
Yes, TruBlu02 that would be correct for a glow/gas powered aircraft. Thank you for catching this.
The wiring set-up I initially described was for an electric powered system where the power connection from the BEC must also carry the throttle signal from the Rx back to the ESC.
I am uploading a revised instruction diagram to the original post
Thanks again for your careful read of the posting
Barry
Old 02-24-2008, 12:39 AM
TruBlu02
TruBlu02's Avatar
Thanks for clearing that up Barry! I just got a Flycamone2 formy birthday from my wife so I am still in the learning prcess with it. What else can that adapter port be used for?
Old 02-25-2008, 07:14 AM
barryp
Hi TruBlu02,
I don't know much more about the mounting base and it's connective functions beyond the information in the manual. In addition to power for the camera, it provides a channel for the recording on-off function. According to the manual, connecting pins 1 and 3 will activate recording or take a single still picture. Breaking the connection will stop the recording. I assume one would do this with an aux channel. There is a firmware update (issued January 20, 2008) that should be installed if you want to use the remote activation features. See the FlyCamOne2 web site for more information about that.
http://www.flycamone2.com/
Happy flying!
Old 02-25-2008, 01:49 PM
TruBlu02
TruBlu02's Avatar
Thanks Barry. I really think the Flycam could come with a better manual but I am definately going to download the update. I have been wanting a way to remotely activate the camera and I have a spare retract channel that needs a purpose in life! I made my first video yesterday with my Reactor and I will post it up later in this forum.
