sig rascal 110 and mini cam
I have a rascal 110 and an aiptek mini cam sd. What i want to know is if i were to tape this cam to the wing leading edge would it make the plane not fly right. I mounted it on the top of my glider and the glider would not climb even with the elevator pulled all the way back. I figure the rascal has a lot more power than the glider so it should be no problem but i dont want to crash a 400 dollar plane. Thank you.
AR,
From an aerodynamically point of view you should avoid mounting anything on top of the wing. Leading edge is a no no. It gotta be clean so the air will follows the surface.
My suggestion is that you use the fuselage,if possible, or you mount it under the wing.
Good luck!
Good luck!
