Editing
Editing
Hi all, 2 Qs
Im using a FCO2 and wanting to down-load to the video forum but the max is 100mb
The camera is at 164mb.
Can I still down load it? or shorten it to 100.
what is an simple edit program to use just a basic edit?
Thanks.
Thanks.
QC, CANADA
RE: Editing
You need a convertor or a coder... http://www.avs4you.com/AVS-Video-Con...FQKaFQodbAbkXQ should do it.
You will need to fiddle a little with the compression to find "your" right way.
Enjoy !
Souglow.
Enjoy !
Souglow.
My Feedback: (10)
CT
RE: Editing
I expect your video files are .AVI format. If you have some editing software like Pinnacle or Adobe Premiere, you can edit and re-process the video into MP4, which might be 20x less space if you adjust the compression parameters accordingly. Plus, editing will allow you to remove any unwanted/uninteresting footage.
Hope this helps.
Hope this helps.
