GPS Transmitter
GPS Transmitter
Hi guys,
I was wondering if anyone has tried equiping GPS in their helicopter or airplane such that you can see the co-ordinates with altitude by having a laptop??. I was wondering if anyone was aware of these kind of system??.
kumar
kumar
IN
FL
GPS Transmitter
Yes, there are GPS overlay boards that will do just that:
http://www.icircuits.com/
Tip: Use a GPS that updates every second!
GPS Transmitter
thankyou very much guys, The information was very useful. I have some products to think with for embedding GPS in my heli. I am not sure if I want the video overlay one. because I have a small CCD camera which has in-built reciever along with it. So I guess I will be looking for something which can directly converts the GPS co-ordinates instead of overlay on video. The link which MikeDD sent me has lot of links too, I have to check one by one. Anyways I some good information to work with. Thankyou very much for the information guys.
GPS Transmitter
hi wildblueyawner,
I came across your dicussion yesterday, I was wondering what did you end up doing??. By the way the purpose of my concern of using GPS is maily altidude because I am planning to take picture of the area and find the scale of the picture. But there might be situations where I need the GPS co-ordinate for overlaying the picture in map. Of course my simplest solution would be to equip the heli with GPS and put a servo such that it records the same time the shutter tiggers. But I am also looking at my various options. Let me know if you happen to have some suggestion.
Thank you,
Kumar
Thank you,
Kumar
GPS Transmitter
Re GPS-based altitude measurement, if you need something accurate, the low-end GPS devices aren't appropriate as they are not nearly as accurate as devices incorporating barometric sensors, which are only available in higher-end units such as Garmin's eTrex Vista
Another source for GPS modules Byonics
More altitude stuff - You might be interested in a recording altimeter that can download altitude vs. time data to a pc-viewable chart (excel spreadsheet). The abbreviated name is the "LoLo" Altitude Logger, developed in the Czech Republic. Might be effective if you can correlate the time of your pictures or GPS readings with the altitude charts:
A U.S. Source for LoLo
Original Czech Source (in English)
Another possible approach would be the wireless variometer sold by Thommys called the Picolario & Picolario Spec's that actually speaks the current altitude back to you wirelessly (an English version is available, and you need a scanner receiver) upon command or at regular intervals. These aren't cheap at $300 for the transmitter alone. I have one, but it's another toy I haven't gotten around to trying yet.
GPS Transmitter
I wish I had some money to get some kewl toys like that....... By the way I think I am going to give byonics a call tomorrow. I looked at the Picolario, looks interesting but couldn't understand. If you happed to have any online documentation in english please do let me know.
By the way is your project for any specific purpose??. Just curious. Thank you for your help and valuble informatiom
Kumar
Kumar
GPS Transmitter
GPS Transmitter
Hello,
you can find the latest information on the picolario under
www.picolario.com
Beginning next week there will be a special US-version available. This one is working on the FRS-Band. It can be ordered at www.picolario-usa.com. This US-Version also uses US-units (feet instead of meters)
Thommy
www.picolario.com
Thommy
GPS Transmitter
hi guys,
Anyone try to use DGPS system?. I know that DGPS has a accuracy of 5ft , I came across this page during my search for optimized system http://www.rsr.org/dgps.html. I was wondering if anyone else has used this kind of system??.
Thank you,
Kumar
Thank you,
Kumar
FL
GPS Transmitter
Actually, DGPS requires a ground station referencing receiver to be connected to your GPS (Garmin uses GBR 21). WAAS is better, Wide Area Augmentation System. The GPS constellation references several ground stations by itself and then your WAAS enabled GPS receiver (newer ones) will receive the WAAS augmented signal ON ITS OWN and the accuracy is around 3 to 7 feet. So find yourself a WAAS enabled GPS unit and you wont need DGPS! Its great!!!
FL
