What are this waves??
Hello,
Today I tryed to take some pictutres with my Trainer with the =S 46 FX (while my electric engines for the Movie-Star don't arrive). And this is what happened... Anyone knows what this is and how to correct it?
Thank you!
Thank you!
Paul this is discussed over on ezone. The vibration from your engine and propeller are causing that. As the shutter works the camera is catching the minor movement of the vibration. To fix it make sure your prop is balanced and take your pictures at idle. If that doesn't work make a softer mount between the airframe and the camera.
HTH
Tom
HTH
Tom
Ezone!
Raul,
Try this address to ezone for the fix of the vibs.
http://www.rcgroups.com/forums/forum...s=&forumid=128
Eric
Eric
