Micro HDTV wireless video camera
<o></o>
The main advantage of MMC-1105 is that, it can attain super high resolution of video image, which is 3-10 times more than previous micro wireless cameras. MMC-1105 can allow the user to see the very details in the picture screen.
<o></o>
MMC-1105 has great value in military & civil use. If it is used to replace the airborne camera on TUAV ASN-15, its real-time video resolution can greatly surpass USA Raven and UK Desert Hawk, the video resolution indexes of the two latter ones will behind the TUAV with MMC-1105 more than one grade.
If used for police for real-time monitoring, the high definition picture of real-time video and later-recall video will greatly help the police to attain importance evidences and to solve the cases successfully.
<o></o>
For real time wireless monitor use, its resolution can be HDTV 1280×1024; its definition is 3-10 times as the equipments of former microwaves and COFDM. If use it for low altitude aerial photography, you can see clearly the brand name of the cigarette box on the ground don't need change the lens focus. For book photographing or evidence taking, at one time it can photograph clearly all the letters on 2<st1:chmetcnv w:st="on" unitname="a" sourcevalue="3" hasspace="True" negative="True" numbertype="1" tcsc="0">-3 A</st1:chmetcnv>4-sized papers. The above-mentioned performance of MMC-1105 is beyond the normal PAL/NTSC videography equipment can do, including some of the equipments for broadcast use.<o></o>
<o></o>
Taking advantage of the most update 2.4GHz BroadRange RF blind-area compensable technology, in outside high mountains area or among congested urban buildings, the signal transmission of MM-1105 is much better than the equipments of microwaves and COFDM. Such as for aerial photography, the distance can be more than <st1:chmetcnv w:st="on" unitname="km" sourcevalue="10" hasspace="False" negative="False" numbertype="1" tcsc="0">10KM</st1:chmetcnv>.<o></o>
<o></o>
<o></o>In fact, MMC-1105 is a Digital HDTV Wireless Camera. It is very different from common wireless cameras. All the performance indexes of MMC-1105 are beyond the common wireless cameras can reach. edimaeg at gmail dot com
<o></o>
More information, please see http://www.edimaeg.com/camera.htm and Actual-Photo and Video<o></o>
Resolution of Image Sensor: SXGA 1280 x 1024 10 frame/second, XGA 1024 x 768 30 frame/second
Sensitization of Image Sensor: < 0.5 [email protected]
Size: 93×72×23 mm (not including the projecting part)
In this mode, the MMC-1105 Center will be temporarily abandoned.
1. One MMC-1105 included a 4800maH Li-battery, which can provide power for MMC-1105 to work continuously above 10 hours.
2. One 2dB high gain foldable short antenna, SMA interface, used for MMC-1105.
3. Two focus-adjustable micro MMC550 lenses, included cable and plug.
4. One 5V charger with indicator light, for batteries inside MMC-1105.
5. One medium-powered receiver of NETGEAR WG102 included one standard 5dB gain antenna, Power Supply AC and its manual.
6. One 16dB high gain panel antenna, size in 20×25×5cm, which has directivity of 60-degree angle, can replace the original 5dB gain antenna to work with WG102 for long distance use.
7. One out-laid 12V Li-battery, included charger, it can be used with WG102 receiver for outside fieldwork, it can provide power for WG102 receiver to work continuously above 10 hours.
8. One mini USB cable to transfer to Ethernet interface.
9. One 500mW High Power WLAN Card
10. One manual for MMC-1105
Appreciate your feedback.
Weight: 125g (including built-in 1200maH lithium battery, which can support MMC-1105 to work continuously more than 3 hours.)
It is the ground video record of actual operation of Mini HDTV Wireless Video Camera MMC-1105 in high sky, which is recorded by 3rd party record software, ZD Soft Screen Recorder. From this video, you can see the unique First Picture-Then Video image wireless transmission technology of MMC-1105. Please watch the video with the video players support HD 1280*800.
In this video, MMC-1105 has opened the function of automatically-adjust-frame-rate. Though the frame rate of most parts of this sample video is only 3-5 frame/second, some parts is even 1 frame/second, every frame of picture is still very clear. In the time at 0:33, we can see it need only a very short time for the operation to gain high-definition picture (from the video, for the delay of ZD Soft Screen Recorder, we see it needs 3 seconds or so to do so ).
The unique First Picture-Then Video image wireless transmission technology of MMC-1105, enables the image definition only decided by the speed of shutter of the lens, no matter what the hardware is and how the surrounding environment is. In fact, in low altitude environment with sufficient light, when the speed of the shutter achive 1/15,000 second, it can work with the aircraft with speed more than 500KM/hour to gain high quality picture.
Note: As in high sky common model airplane can not be stable enough for the camera to photograph, higher quality video require the model airplane must be more than 6KG and with areo phtography platform, please wait and see our next sample video. THANKS.
As the video is 386.3 MB, we have tried many times to upload it on www.viddler.com, but finally fail. Please go to the following link to download it, THANKS.
http://www.filefront.com/15843659/20100307%2303.wmv
(Note:copy the link to your IE address, when you find it is 386.3 MB then you click download, if not, please be patient to wait the page open to you, then click download button on the page)
Any questions, please contact edimaeg at gmail dot com
http://www.viddler.com/explore/edimaeg/videos/2/
http://digg.com/d31MZ6Z
