How about this quadcoptor for aero photograhpy?
1 Attachment(s)
Detailed info for IFLY4 originated from China.</p> Weight & payload Body weight: 620g; Payload:400g; Maximum Takeoff Weight: 1,100g;</p> Motor: Bushless Motor: (IFly2212)11.1v; Power:200W; Drive Configuration: direct drive for each axis Governor: 15A digital governor</p> Size: width: 57cm ; length: 57cm; Distance of motors: 45cm ; Height : 25.4cm</p> Built-In Functions: Low Voltage Protection ; 2-axle Gimbal Support;</p> Peripheral: Fixed Quadcoptor;</p> Supported ESC output : I2C (200K)</p> Recommended Transmitter : Radio compatible to PWM output, 6 channels at least.</p> Assistant Software System Requirement : Windows XP SP3 / Windows 7</p> Working Voltage Range: MC:4.8V~5.5V</p> Power Consumption : MAX1. 5W (0.3A@5V), Normal:0.6W (0.12A@5V)v</p> Operating Temperature: -10°C ~ 50°C.</p> Working environment: Ambient Humidity: <%80, Ambient wind speed: < 4m/s</p> Weight : MC:25g</p> Dimensions : MC: 45.5mm x 31.5mm x 18.5mm</p> Flight Performance: Max Yaw Angular Velocity: 190° / s Max Tilt Angle: 45°</p> Sensor: 3-axis gyro + 3-axis accelerometer, can be upgraded to 9DOF. Props dimension: 1045 10inches props*2pcs and 1045 10inches Anti-rotating *2pcs. Props material:Plastic Parts replaceability: Dedicated to Idea-fly products FPV availability: Compatible but not included. Altitude hold: Not available.</p> Optional: Camera mount($40/pc): Camera Mount with vibration isolation,Material: carbon fiber,Number of axes: single axis, Battery($20/pc): 3s‘2200 mAH, Maximun 15mins for free flying, 10min for burdened flying(1030g,including camera,PTZ),$15/pc freight cost for additional batteries as ristriction on inflammable material.</p> Packaging option: I: Big and colourful package: Including IFLY4*1pc($285)+Camera mount*1pc($40)+Battery*1pc($20), unfolding then ready to fly. Total $340 without delivery cost.</p> II: compared to I, excluding battery, packed in small package, need to assemble props after unfolding, then ready to fly. Total $325 without delivery cost</p> III: compared to I, excluding battery and camera mount.packed in small package, need to assemble props after unfolding, then ready to fly. Total $285 without delivery cost</p> All original parts out of our factory in Shenzhen China, total different quality to other places like GLB. For the small package, it could easily be assemble after reading the manual. Delivery cost depends on where you lived. please give me your address and zip code for freight cost query.</p> Please contact me if you need me: [email protected] Google our videos or check out our websites:http://www.idea-fly.com"]www.idea-fly.com[/URL] for more. thanks.</p> |
RE: How about this quadcoptor for aero photograhpy?
Surprise waiting for first 5 person in EU</p> |
1 Attachment(s)
More pics and you can google our videos for more. thanks.
1 Attachment(s)
ESC
Hi. I have been researching quad copter kits and this is the best I have seen yet!
I do have a few questions: why are there 2 servos shown on the camera mount if it is single axis only? Will it be able to carry a DSLR camera like a Sony a300? Also, I live in Canada. Can I still order one? Thanks in advance. Regards Robert |
Hi Robert, We're using the white one, sorry for the confusion, camera mount we offerred here is only single axis, but you could update it two double axis if you want, Our maximum payload is 1100g(including the IFLY4A and camera mount), so it's up to your camera, Would you letme know you address and post code? i will assess the freight cost for you, thanks. Please mail you info tome :[email protected] Tristan.</p> |
It looks like the other servo is for the shutter.
Joaquin |
1 Attachment(s)
More pics
1 Attachment(s)
Motors
1 Attachment(s)
Caps
1 Attachment(s)
Pics
It would be nice, however, if you have one like mine from Ideafly, be careful since mine has flipped 4 times now for no reason. It also has a glitch that makes it dip for a split second, usually recoverable. But the " Death Flip" is never recoverable. The last time it happened when it was over asphalt. Cost me the landing gear and a canopy. It will be flying great and steady and all the sudden it seams like the two right side engines just shut off. I have posted to bulletin boards and to Ideafly for help and no one seems to have the same problem, or answers for me. I am going to replace all 4 esc with 20amp units to see if it helps. Good luck.
Try this voltage protector. Seems like you're suffering from brownouts.
http://www.hobbyking.com/hobbyking/s...f_1_4sec_.html |
