High altitude LOS no FVP
Can we continue this without the bs? I want to fly high and take pics. No fpv and yes it will be in my line of sight. Some planes I have read that people use are:
radian bixler spy hawk wing dragon any others? would would you recommend? I have read that a lot of people use bixler cuz it's cheap.<br type="_moz" /> |
RE: High altitude LOS no FVP
I didn't see any BS in your other thread. I saw lots of concern that a newbie wants to fly above the legal altitude for models near an airport, but that's about it. For the goal of safely and legally shooting some aerial photography, you'll want as large a plane as you can manage both for visibility and to carry the extra weight. The Radian is an all around nice plane that many have had as their first. If this is your first plane and you're going it alone (not my recommendation but if that's what you've decided to do there won't be any talking you into anything else) it would be the one to get. There's not anything cheaper that's just as good, but there may be some cheaper planes that you'll like well enough. If you get good at flying the plane, especially at finding and riding the thermals, it's a simple step up to add a camera to it and start filming your flights or snapping pics with a servo actuated shutter.
ORIGINAL: jester_s1 I didn't see any BS in your other thread. I saw lots of concern that a newbie wants to fly above the legal altitude for models near an airport, but that's about it. For the goal of safely and legally shooting some aerial photography, you'll want as large a plane as you can manage both for visibility and to carry the extra weight. The Radian is an all around nice plane that many have had as their first. If this is your first plane and you're going it alone (not my recommendation but if that's what you've decided to do there won't be any talking you into anything else) it would be the one to get. There's not anything cheaper that's just as good, but there may be some cheaper planes that you'll like well enough. If you get good at flying the plane, especially at finding and riding the thermals, it's a simple step up to add a camera to it and start filming your flights or snapping pics with a servo actuated shutter. <br type="_moz" /> |
There are several very good, beginner sailplanes, for your basic high altitude flying, without FPV. A few of those are; Easy Fly @ 1.9M wingspan,<div>Parkzone Radian @ 2M dehydral wingspan (Floater), Bixler (If you want something smaller, but faster), more for FPV'ing, and the new much larger Super Sky Surfer @ 2.4M wingspan and a fuse slightly over 4 feet long.</div>
1 Attachment(s)
It would be best to get a plane with a rear motor pusher prop for photography / video purposes. The EZ Star would be a good starter ( http://www.multiplexusa.com/model-kits/easy_star.html ) and the X8 ( http://www.youtube.com/watch?v=hqzoG...creen&NR=1 ) would be very good. If you go with the Easy Star, enlarge the rudder surface a bit, adding ailerons will also give quicker control response. Another good plane would be the RQ 11.
ORIGINAL: LarryV It would be best to get a plane with a rear motor pusher prop for photography / video purposes. The EZ Star would be a good starter ( http://www.multiplexusa.com/model-kits/easy_star.html ) and the X8 ( http://www.youtube.com/watch?v=hqzoG...creen&NR=1 ) would be very good. If you go with the Easy Star, enlarge the rudder surface a bit, adding ailerons will also give quicker control response. Another good plane would be the RQ 11. |
How would this compare to the Raidan, its $100 less. http://www.hobbyking.com/hobbyking/s...arehouse_.html</p> |
The Radian is a good flyer but for photography and video purposes its not good because the prop is in front. A prop / motor in front is going to cause prop distortion and electrical interference with your camera, You can overcome this by mounting the camers backwards toward the tail or outboard on one of the wings, outboard on a wing is not going to be as steady a platform as a center mount and mounted backwards is not a good picture.
I would say no to this because of the motor in front.
IMO, the most suitable platform would be one of the larger "old-timer" models.
Large, lightly-loaded and most importantly, possessing bags of inherent stability. You can fly it to a dot without fear of losing control. Easy to fit a camera outside of the prop arc. Doesn't need much of a power unit to get it aloft.... you could use electric and have the luxury of switching off whilst doing the important video work. Tons of room inside the fuselage. Ditch the undercarriage and handlaunch it. No undercarriage means you open up the possibilities of flying in more diverse locations. These models can often be had very cheaply, too. |
ORIGINAL: Wrice4 Can we continue this without the bs? I want to fly high and take pics. No fpv and yes it will be in my line of sight. Some planes I have read that people use are: radian bixler spy hawk wing dragon any others? would would you recommend? I have read that a lot of people use bixler cuz it's cheap.<br type=''_moz'' /> |
Wrice4,
I hope you find all the info you are looking for and are succesful in your venture. I cannot help since I have no experiance in this matter, although I have taken my 35% to altitudes that border the unimaginable. I fly an old JR Ham Radio and it works great! As for those, including the Mods who think this is a silly idea and could "Close the Hobby" Thats just ignorance. It could effect what you are able to purchase at the LHS or perhaps what can be offered to the public, but with no real way of enforcement it is impossible to belive that our doors could be closed. People will always be able to fly RC in our united states, Even with our current Administration! |
People will always be able to fly RC in our united states, |
The Radian, is an excellent aircraft for photography, I know, because I've set mine up for both photography, as well as, videoing. You just have to know how to build and place your different mounts, depending on what you prefer to do most. Not going to bog you post down with my vids, so I'll just add this one, but if you guys care to see some of my other vids that show my camera facing forward without motor obstrucion, just view my channel.<div>
</div><div>[youtube]http://www.youtube.com/watch?v=BNlKKcvnvlA[/youtube]</div> |
ORIGINAL: Maximilionalpha The Radian, is an excellent aircraft for photography, I know, because I've set mine up for both photography, as well as, videoing. You just have to know how to build and place your different mounts, depending on what you prefer to do most. Not going to bog you post down with my vids, so I'll just add this one, but if you guys care to see some of my other vids that show my camera facing forward without motor obstrucion, just view my channel.<div> </div><div>[youtube]http://www.youtube.com/watch?v=BNlKKcvnvlA[/youtube]</div> |
ORIGINAL: G4guy ORIGINAL: Wrice4 Can we continue this without the bs? I want to fly high and take pics. No fpv and yes it will be in my line of sight. Some planes I have read that people use are: radian bixler spy hawk wing dragon any others? would would you recommend? I have read that a lot of people use bixler cuz it's cheap.<br type="" /> |
Out of all of the previous sailplanes that I mentioned to you in my earlier post, I would strongly suggest to you, the Parkzone Radian, being that it's a very good floater, with its' dehydral wing shape. Also, if you're skiddish about flying,, may I also suggest this free simulator program for you, rcdeskpilot.com as, well as, a few Radians to add to it for practice with them. http://www.rcgroups.com/forums/showp...;postcount=985
ORIGINAL: Maximilionalpha Out of all of the previous sailplanes that I mentioned to you in my earlier post, I would strongly suggest to you, the Parkzone Radian, being that it's a very good floater, with its' dehydral wing shape. Also, if you're skiddish about flying,, may I also suggest this free simulator program for you, rcdeskpilot.com as, well as, a few Radians to add to it for practice with them. http://www.rcgroups.com/forums/showp...;postcount=985 |
Okay, sorry, no offense.http://www.rcuniverse.com/forum/js/f.../red_smile.gif If it's all the same to you though, a simulator showing you the flight characteristics of the sailplane, especially the 3 channel kind, I think, would aid in your final decision.http://www.rcuniverse.com/forum/js/f...wink_smile.gif
ORIGINAL: Maximilionalpha Okay, sorry, no offense.http://www.rcuniverse.com/forum/js/f.../red_smile.gif If it's all the same to you though, a simulator showing you the flight characteristics of the sailplane, especially the 3 channel kind, I think, would aid in your final decision.http://www.rcuniverse.com/forum/js/f...wink_smile.gif |
