moving CG around
RE: moving CG around
Come on Shawn, most models need adjustment. Not just the CG, but usually everything else as well.
To answer the OP's question if you are moving the CG by just adding weight, take the weight you are adding and divide that amount by the overall airplane's weight. The amount that the CG moves will be that fraction times the distance from the original CG to where the weight is added.
Example, if 1 oz. is added to a 6 lb. airplane and it is placed 24 inches behind the original CG, then the CG moves back 0.250 inches. Moving a 4 oz battery, you would have to move it 6 inches back. It's best to work out most of this during construction.
My Feedback: (29)
So true Bob, that has been one of the most difficult thing for me to get across to people. Trimming for me is always a work in process. I kept my answer on this one simple so that the OP would hopefully let us know why he wanted to play with his CG location and then we could go from there. In the past trying to explain that CG will change everything from landing speed to control cross coupling with about a dozen things in between always seems to spark arguments. Seems the old pilots tale of a nose heavy airplane always being more stable is alive and well.
