sig wondere
sig wondere
hello
anyone now the profile on the sig wondere, i got profili sow i want to build this model after a small drawing i got off it
best regards to all you modelsflyers
michael from denmark
He is looking for a trace of the airfoil.
Micuyou, it's also entirely possible that the original airfoil is not something specific. I know that if I were building something like a Wonder I would most likely use an airfoil with a flat rear portion to make building the wing easy and fast.
Some years back someone asked how to do this style of airfoil in a "cheap and dirty" way. I posted this as one possible option. It's not a brand name airfoil but for something like a Wonder it would be good enough if you can keep the model weight low.
I built a replica of the Wonder and asked some questions in this thread: http://www.rcuniverse.com/forum/aero...cal-tails.html
I used a NACA 4-digit modified for my plane. But I used the airfoil to make a template for the ribs, then sheets were added and the trailing edge were cut for flat ailerons, so it's not exactly the same airfoil.
The airfoil I used was; [ATTACH]1928673[/IMG]
Hope that helps!
Hope that helps!
The Wonder was a Bruce Tharpe design when he worked at Sig. As with most of Bruce's designs he liked to use a simple semi-symmetrical airfoil that flew well. Heck if it ain't broke don't fix it. I'd bet my Flyin' King has pretty much the same 4 star airfoil. Trace a 4 Star tip rib and you'll have it. It is flat from the spar to the trailing edge but only on the bottom. The top follows the airfoil's natural curve. It's partially flat on the bottom for much easier building as you can build it flat on the board without use of shims or blocks. It fly's much like a symmetrical airfoil due to the "flat" portion angle upwards as viewed from the side. Good luck on your Wonder. I've long wanted to build one and always have had a good 15 laying around.
Peace,
J
Peace,
J
Peace,
J
Peace,
J
Bob
Right now it is my favourite plane. Just charge and go. My Twist is better as well as maybe another one or two, but I like the simplicity and little consequence of it. Mine came out a bit (lot) tailheavy from a swap meet find and I needed a heavier motor as well as extending the nose a bit, so I took out the LA .15 and put in the Fox BB. It goes great and if I need more speed (and I do) I will put on the Turbo head I made up, and maybe a higher pitch prop. Maybe later the ASP blue head .15 that I got turning up real good. It takes about 30 seconds for me to get up to full throttle, and then at the end of the tank I want more speed. Yes it is a symmetrical airfoil.
Sorry If I was misleading guys. I assumed the wonder used a four star like airfoil but have never built one. He used the same basic foil for the 4star, Venture, Flyin King and the Reaction Jet. So these Wonders are little hot rods with a good 15? What is one like with a cheap 25 like a LA? You guys got me to thinking I might need a hand lauched screaming little hot rod.
Peace,
J
Peace,
J
