Go Back  RCU Forums > RC Airplanes > Aerodynamics
Reload this Page >
Airfoil for a Airbus A320 -suggestions-
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Reply
Old 02-20-2018, 05:11 AM
baco
baco's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Airfoil for a Airbus A320 -suggestions-
Hi Guys
I'm interested into build a EDF Airbus A320 , but want to build a CNC cutted wing using a good airfoil, better than these generic seen many times in some build videos in Youtube. Any suggestion?
baco is offline
Old 02-20-2018, 07:31 AM
All Day Dan
All Day Dan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Try here. Dan
flyingfoam.com
All Day Dan is offline
Old 02-20-2018, 12:25 PM
BMatthews
BMatthews's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The size and expected flying speed will also play a part in your airfoil decision. Also the structure you will use for spars inside and what you're using for a skin over top of the foam if any. So all in all it would be good to have more information on the size and construction details. In addition is the intent to make the model large enough that you also use flaps to aid with takeoff and landing speeds.
For a larger sort of size I'd also want to look at the thickness of the full size so you can match the airfoils that are better at model size to the same percentage thickness for a more scale like appearance.
BMatthews is offline
Old 02-20-2018, 03:46 PM
baco
baco's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm thinking in a single 70 mm diameter EDF which means some around 1200 mm wingspan. A carbon rod can be used as longeron, will be fitted with light weight retracts and all model can be made in foam paper covered. I'm asking for a A320, cause is more familiar to everybody, but in fact want to do this particular model: FMA Condor II, designed by Kurk Tank in Argentina circa 1955.
ID:	2255391   Click image for larger version
ID:	2255392   Click image for larger version
baco is offline
Old 02-21-2018, 02:41 PM
fumus
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Airliner
fumus is offline
Old 02-22-2018, 02:19 PM
BMatthews
BMatthews's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What an intriguing design! ! ! !
For a model of that size span and area there's no point in going crazy with fancy options. The small wing chord will make shaping of a really critical airfoil too fussy to bother with. I'd say you want SOME amount of camber but not a flat bottom section. Make something that looks more or less like a NACA 2410 and call it a day. Or you could use a Randi Randolph style airfoil of 10% thick and it would be fine. What's a Randi Randolph style airfoil you ask? Randi had a number of his RC sport flying designs published over the 20 year span from around the late 1970's up near the turn of the millennium. Some used a fairly flat bottom shape and others used a low camber nearly symmetrical shape with a flat rear portion to sort of simulate an airfoil which would be much like a NACA 2410 but with a flat lower rear portion. Although if you look at that link above it would not take a lot to flatten the rear underside half of the shape. Either way the flat shape allows you to build the wing easily on a flat building board. And at this size it's as good a shape as any.
A primary concern is going to be to keep it light. The aspect ratio is high so there's not a lot of wing area. On my screen the top view has a 90mm span and a 10mm chord at around where I'd expect the MAC to be. Scaling that up to 1200mm means a 133mm chord. And that's about 50 to 70 mm smaller than most sport model wing chords for that sort of span. That's going to cut into the wing area so making the model lighter than the span would suggest is going to be pretty important if you want a friendly sort of landing and takeoff speed. I know you want retractable gear but keep in mind that such gear assemblies and the hard points in the airframe to allow using them can add up to a lot of that weight. You may want to consider a takeoff dolly and belly landing in the grass instead. The in flight performance for both climb and even speed would be better.
Old 02-22-2018, 08:16 PM
baco
baco's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
BMatthews thanks for you answer, I agree with your concern on weight. I have a VERY lightweight retracts set, and I want to use the cause I live in a desert and there are not grass fields. So wheels are madatory.
Thanks for your comments. I will do a new post as soon as I beging building Condor II,
Also found factory wing plans of this plane. Probably show some differences from previous pictures cause was a different stage of this project.
Name:	Avion rapido de transporte.jpg
baco is offline
