Funtana KE ?
Funtana KE ?
Hey guys, I have a H9 Funtana 100 and when i do a KN edge it turns into it hard. I have to use a lot of down elevator to correct. Can i have built it wrong. Or do i just need to add a mix into the radio.
My Feedback: (19)
RE: Funtana KE ?
It balances too far forward-If you can, remove some weight from the nose and /or add weight to the tail. Then retrim the airplane with less up elevator, which is causing your Funtana to turn when it is on its side. Let me know how you make out.
harvee
harvee
