Go Back  RCU Forums > RC Airplanes > Aerodynamics
Reload this Page >
prop exchange for best performance wedgie
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Reply
Old 05-05-2008, 10:43 AM
suzonka
My Feedback: (7)
suzonka's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default prop exchange for best performance wedgie
I have a wedgie ,its and older version of the zaggi wing but shorter in spand. I have a speed 400 electric motor on it with 9 cells and it moves pretty good except I broke the Gunther white plastic prop on landing, so now I have 3 props to choose from to replace the 5x4.3 push on Gunther prop, I have a maser air screw gf series 6x4.5 ,and as 5x4 grish nylon and a 7x3 master air screw gf series, now which prop will give the the most for power and duration
suzonka is offline
Old 05-07-2008, 05:15 PM
Mike Connor
Mike Connor's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: prop exchange for best performance wedgie
The 6x4.5 would double the load and the 7x3 would almost triple the load so the 5x4 may be your only option. I am not that good with electrics but here is a calculator that should give you the info you want.
http://brantuas.com/ezcalc/dma1.asp
Mike Connor is offline
Old 05-07-2008, 08:09 PM
suzonka
My Feedback: (7)
suzonka's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks ,I looked up the specs and the 5x4 is best for duration and static thrust
suzonka is offline
Old 05-07-2008, 08:18 PM
suzonka
My Feedback: (7)
suzonka's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Mike Connor
thanks Mike
suzonka is offline
