aircraft design?
My Feedback: (10)
GA
aircraft design?
I am trying to understand how tail surfaces are sized for aircraft. I have always used a basic design guide of 18 to 20% of the wing area fot eh H stab and 1/2 that for the V stab and this has always yielded good stable flying airplanes.
I know tail sizes seem to vary a bit on full scale aircraft.
I have been doing some searching on the net a I came across a few terms that are used in determining the h stab size and the CG range.
Neutral point
Static Margin
Aerodynamic Center
Center of Gravity
Tail Volume Coefficient.
From the things I read the CG should never fall behind the NP or the plane becomes unstable.
Static margin is generally 5% to 15% for a nice and stable plane.
Aerodynamic center is located about 25% of the wing chord of a square wing.
CG is ideally located slighty behind this point but ahead of the NP.
I dint quite get the Tail Volume Coefficient.
The way I see it is it doesn’t make any difference what size the H stab is as long as the cg is ahead of the NP. However ideally you want the CG around the AC so the tail size and length would be tailored to align the CG and AC.
Please someone with knowledge in this go into more detail.
Grant
Neutral point
Static Margin
Aerodynamic Center
Center of Gravity
Grant
RE: aircraft design?
I'm not sure what you might have missed, but you've asked for about one semester's worth of Aero101.
You can get most of those terms depicted in the application linked here:
http://www.geistware.com/rcmodeling/cg_super_calc.htm
I've included an attachment that shows what you see at that link. The arrows show one detail.
The sizes of things like the H-stab and Elevator (they are the horizontal part of the empennage) aren't the only consideration. Size matters, but equally important is the distance a structure like that is from what it's supposed to stabilize.
There is a good book that covers what you've asked about. BASICS OF R/C MODEL AIRCRAFT DESIGN by Andy Lennon. It's often found in LHSs, but is also available off the internet. It's probably $20 in the LHSs.
ORIGINAL: grant-RCU
Neutral point
Static Margin
Aerodynamic Center
Center of Gravity
Neutral point
Static Margin
Aerodynamic Center
Center of Gravity
It makes a difference. And you usually move the CG to suit a design that is appropriate to the task. Tail size and moment will be designed to deal with controlling the pitch of the wing and provide pitch stability of the airplane. You'll move the CG to establish decent pitch stability when you're building the sucker and later to tailor your elevator response for more pleasing flying.
Da Rock knows his stuff
Us layman could look at the Tail Volume Coefficient like weight and balance. The further back the weight the less it has to weigh to have the same effect. The further back the tail is from the CG (longer moment) the smaller it can be to have the same effect.
