Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Unstable flight
Reply
Old 05-13-2008, 09:47 AM
egrave
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Unstable flight
I have a airplane low wing. I have balanced it front to back side to side I have check it with a incidence meter. I have put it on a level plane and check the height of the wings and they were the same height. Yet when I try to fly it I have to put the trim all the way to the right to make it fly level. Can some one tell me what is wrong
egrave is offline
Old 05-13-2008, 10:37 AM
HighPlains
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Unstable flight
Sounds like a warped wing or the ailerons need adjustment.
HighPlains is offline
Old 05-13-2008, 11:44 AM
crasherboy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You don't by any chance have a bad servo,do you?
does it seem okay when you rev the engine on the ground? If that is okay you must have a warped wing.
crasherboy is offline
Old 05-14-2008, 03:38 PM
DanSavage
DanSavage's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: egrave
You made no mention of engine offsets, rudder offsets or horizontal tail offsets. All of these could cause the airplane to roll.
How about posting some pics so we can see the airplane for ourselves?
Dan
DanSavage is offline
Old 05-15-2008, 08:58 AM
Rodney
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Most probably a warped wing.
Rodney is offline
Old 05-15-2008, 03:10 PM
mjfrederick
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can check for a warped wing easily with the incidence meter you mentioned. Keeping the airplane level, put the meter on one wingtip, record the reading, then put it on the root of the same wing. Repeat for the other wing. Any difference in angles will tell you where the warp is. If it is a built-up monokoted wing, you may be able to twist the warp out using a heat gun and a little elbow grease. If not... I wish you luck...
mjfrederick is offline
