Rudder only flight with a 4 channel trainer.
#51
RE: Rudder only flight with a 4 channel trainer.
That Babcock 3-tube single channel radio Hal used weighed more than many REMA electrics weigh today!
The 67-1/2 vokt B-battery that powered it was close to a pound!
#52
ORIGINAL: HighPlains
Interesting but a bit hard to read. I find 1 Meg setting on the digital camera works better for text. Only problem is you have to do a couple of entries because of RCU limitations.
It's only hard to read because of how RCU presents attached pictures. Instead of just clicking for a "larger" view which isn't large enough try right click and "save as" then open the pages in a graphics viewer that you can zoom more easily. The file size is up around 240K so it very readable when you make it bigger.
#53
Actually, if you click to enlarge you get an not-so-good enlargement BUT IT HAS A BLUE BUTTON in the lower right corner. Click that and you see the attachment at it's original size. At least with those page copies, they become readable.
#54
I was looking at it after the Blue button click. You will notice that there are a lot of aliasing effect when looking at the photos in the article. This means the sampling rate or resolution of the camera is too low. For instance, here is a picture taken from a similar publication in the 50's with the same dot spacing. No aliasing because the resolution of the camera is high enough.
#55
I rescan them at at a higher res and see how that works.
I really like how your post looks.
My new scanner has a 200 dpi default I forgot about, along with descreen.
and I should have remember that one here is the first one...
The binding is so stiff it is hard to get the page flat on the glass...
Perhaps I should just get out the Nikon and try some Macro shots...
I will try to clean them up a bit more I do not like how the first one came out.
I could read them when I opened them in photo shop but they are nasty looking with the web browser.
If you can read the table on the page a 76 oz plane flying with a .25 engine, we use a 40 at least today.
#58
One thing I do recall is that planes with rudder only or rudder and elevator had a lot more dihedral than today's airplanes. Even an lt 40 seems to have a lot flatter wing than my old Berkley cub had, I think it was around 3 inches high at the wingtip.
