Two Islands
Two Islands
There are two mythical islands out in the Pacific ocean, on the same meridian. The north island is 30 degrees north of the equator, and the south island is 30 degrees south of the equator. Both islands are the exact same size and both are 20 feet above sea level. Both are unique because the wind never blows and no clouds are ever seen from either island.
Our RC club wants to build a flying field on one of these islands and we want to maximize the daylight flying time available over the next 100 years.
Which island should we choose?
RE: Two Islands
Ok, since I'm bored anyway, I'll bite. And I'm not googling anything, just answering off the cuff.
If I'm not mistaken, which I probably am, the tilt of the Earth's axis would cause slighty more daylight time on the Northern island. Of course, in the next 100 years, the Earth could flop on a new axis again, so who knows?
RE: Two Islands
I googled a NASA page and came up with the Southern Hemisphere having a slight advantage right now.
Our orbit is elliptical and the Earth is tilted with the Southern hemisphere nearest to the Sun at the time when we are nearest to the Sun. There are other meterologic reasons why the South might get less cloud cover, too.
The Earth has a wobble on its' axis and the tilt might be either advancing or retarding which could be why HP qualified his question with a 100 year limit.
Now I await the "trick" answer........
RE: Two Islands
I too await the correct answere. He took the meteroligical differences out with his hypothetical question. So I guess it comes down to which hemisphere gets longer daylight hours for more days of the year. I can't find anything that says otherwise, so I'm sticking with the Northern hemisphere getting slightly more daylight because of the tilt.
RE: Two Islands
You both get full credit for the attempt. Take the tilt of the axis, and throw in the elliptical orbit and you are almost there. Knowing when the Perihelion occurs is the missing information. Currently the Earth reaches Perihelion (closest part of the Earths orbit around the sun) on January 3. Kepler's 2nd law says that the swept area in a given time is always equal regardless of the distance from the body that is being orbited.
So in the winter time in the northern hemisphere, the Earth is closest to the sun and going the fastest in it's orbit, thus it spends less time shining on the south island.
There is a bit of variation in all the orbital mechanics over time as surmised, but on a very long time scale - Tens of thousands of years. The tilt of the Earth wobbles, and precession changes where it points. Measurement of this may mean the Pyramids in Egypt are much older than a few thousand years old, since they were aligned to the stars when constructed.
Even the Earth's elliptical orbit precesses due to the gravity of the large gas giants in the solar system.
For a really interesting summary of these and other things see the following:
http://en.wikipedia.org/wiki/Milankovitch_cycles
Thus, summer in the northern hemisphere is 4.66 days longer than winter and spring is 2.9 days longer than autumn.
RE: Two Islands
Well, Highplains, your island ain't in Kansas. You built your field, but some idiot blabbed about it and someone figured out there was an island in the Pacific without a golf course on it. Not long after that the RCers were run off. NOW, does it matter?
Grin,
Bedford
Grin,
Bedford
RE: Two Islands
I was surprised to see that much difference too. As close to the equator as your islands are the Sun will rise pretty high year round.
I should have remembered the part about the acceleration and deceleration during orbit. I've seen a large working model somewhere that included that feature.
My Feedback: (61)
RE: Two Islands
Ok, I've got one:
What is the difference in the straight line and relativistic (curved space) measurement of the distance from the Earth to the Sun.
IE. Earth to sun (straight line)-Earth to sun (relativistic) =?
Calculators and google not allowed!!! If someone gets it I'll tell them.
Hint: Mass causes space to bend (according to relativity).
RE: Two Islands
This is such an easy question to answer. Use the Southern Island because it's the closest to the greatest country in the world, namely Australia. Too easy.
Wedge
Wedgetails rule the skies
Wedge
RE: Two Islands
ORIGINAL: BMatthews
It sure is easy to tell that it's the middle of winter.
Don't you folks have an airplane to build or something?
An old friend said that when he was stationed on Adak in the Aleutians, they'd build models all winter long, waiting for summer.
But... they had a big party that day and no one flew.
RE: Two Islands
More is better, I always say.
Actually, adding depth to the floats to get the nose of the floats out of the water.
And despite the name, Labrador Retrievers don't!
RE: Two Islands
It's not the weather that keeps me inside. It's the dirty big mozzies! I put chicken wire across the windows and it keeps them from getting inside, but I have now run out of chicken wire. There is no way I'm going out side to the car to get more wire netting.
Wedge
Wedge
