Advice for a gas Airplane
Hello
I'm flying electric planes and i want to try my first gas airplane, I am interested in AW 35 cc. What plane would you recommend.?
thannks
Hello
thannks
Match it with the DL30 nice setup. That would be a great setup.
I have the 50cc Yak. From what I'm reading, the extra needs to be flown a bit hotter on landings because of the wing. Yak can be flown slower. My yak will fly really slowly without falling off. My suggestion to you is to stay away from AW planes unless you have the know how to fix some of their problems in hardware or design. They have a selection of planes that have been redesigned many times and those are the ones you should buy although you still need to replace some of their hardware even after so many redesigns. That's been my personal experience and also reflected in this forum by many.
The AW 50cc Yak was my first gas plane. I would highly recommend it as a first gas scale plane. The build is easy, the plane flies very precise, and it floats on landing. Additionally, the plane is a survivor. I subjected it to many hard landings in the beginning (it being my first gas/giant plane and all) with only bent gear and busted wheel pants to show for it!
I use all the AW hardware other than the fuel tank.
I agree, it was my first gas plane and the directions are really helpful. I hit a gopher hole once and it bent the gear back, but that was it. Put a DA50 and a canister on it.
I'd give AW a big thumbs up.
Correction: I had my first tank split at the plug a day after posting this. The foot tastes... well ... not too bad. I still really like my AW stuff but now I have experienced the tank failure issue.
