aerowoks yak dle 30
RE: aerowoks yak dle 30
ORIGINAL: flying.2006
thanks but not happy to do that fire wall will be weak will it hold it .will have to go for a 26 evolution
Mark Dennis
Aeroworks, Inc.
4903 Nome Street
Denver, CO 80239
303-371-4222 ext. 105
if i was to do that how do i get to low end-high end on carb as it will be in firewall do this mean make other hole in fire wall do you think dle 30 is better and make it fit. or go for the 26 evolution easy fitt is there much power diff is the 30 dle 3.7HP any idear about the HP on the 26 evolution witch one wood you use dle 30 £180 pounds.or 26 evolution £230 pounds+muffler £50 not sure which one to buy
have on order 45mm stand offs from gashanger the 6omm are to long with the dle 30 for this plane so i will cut a bigger hole in fire wall so the carb is 15mm in the fire wall thats the only change to do+a small hole in fire wall to ajust high-low end on carb i have a 26 evolution in my global mx2-30 not bad but the dle 30 is more powerful 3.7hp so i will try the dle 30.in my yak hope i am doing the right thing
26 gx evolution is 3.8 hp. max rpm is 9.500 so they say with easy fit glow mounts no making holes in the fire wall plus front carb so easy to put choke on bye hand dle 30 is 3.7 hp. max rpm 8.500 so they say. rear carb stand offs to long 60mm you will need 45mm you will have to cut holes in fire wall for carb plus high end low end and thottle servo in wrong place a lot more work with the dle 30 but it is less money to buy. this is a hard what one do you bye ?
Wish I went with the JC 28cc and not the MLD 28cc.
http://www.youtube.com/watch?v=ZWDEsav7yZU
http://www.rcaer.com/store/Details.c...212&category=2
