Aeroworks Vendor Forum This is the place to go for all your questions concerning anything Aeroworks. Rocco, Mark, and the rest of the Aeroworks staff will be manning this forum so that they can answer all your questions.
DLE20 questions
Old 01-30-2011, 09:48 AM
dusty1966
Default DLE20 questions
Just put a DLE20 in a AW 300Extra and like a glow engines after you are done flying for the day you run the engine out of gas,is it the same for gas engines?
Also with glow engines you have to have acsess to your needle vavle if you have a cowl,on gas engines do you have to adjust the needle vavles every time you fly?
dusty1966 is offline
Old 02-09-2011, 02:58 PM
a1pcfixer
My Feedback: (7)
a1pcfixer's Avatar
Default RE: DLE20 questions
Not needed.
No, adjust the HS & LS properly initially, then other times ONLY when you change props,
mix ratios, and such.
There's two, [.pdf] files in this msg, about how to tune;
http://www.rcuniverse.com/forum/fb.asp?m=10293852
Further support info on the DLE20cc gas engine can be found at the bottom of this msg......
http://www.rcuniverse.com/forum/fb.asp?m=9863953
NEW DLE 20cc Gasser! (Data & Links 1st Post)
.....as well as through out that msg thread.
a1pcfixer is offline
Old 02-09-2011, 04:12 PM
gregman50
No need to run it dry of fuel, and you just need access to the needles to adjust it when first tuning or maybe after break-in. That's why you will fall in love with the gas engines, not to mention the cost of fuel, gas vs. glow per gallon. Hope this helps.
gregman50 is offline
