mounting a gasser to the 90-120 yak
My Feedback: (26)
I have a 32cc gasser that i want to mount on this bird. I need to back the engine up about 3/4" to give me about 1/4" clearance from the cowl. I have read the 2 following senarios and wanted a few more comments from Aero-works and other experienced flyers who have actually done this.
1) Cut the front end off the engine box with a razor knife about 1/4" back....then remove about 3/4" from the middle and re-apply the front using ply and 30min epoxy w/ tri-stock for extra support.
2) The engine came with 2 1/2" stand offs. I have 1 3/4" stand offs which would be the right length for proper cowl clearance but I would have to cut out the firewall for the carb which places the needles right inline with it []
Frank
Frank
My Feedback: (9)
RE: mounting a gasser to the 90-120 yak
I did a similar engine install... and put a DLE-30 on the Yak. I used the shorter stand-offs and cut a hole in the firewall. I also installed a venturi on the carb to avoid any unburned fuel spitting back into the plane. I used a venturi made for the Zenoah engines (Tower Hobbies part #LXYTF4, but don't know if this would work with your engine or not???). There never appeared to be any fuel or evidence thereof behind the firewall. Hopefully you can modify the firewall to allow acess to the mixture screws... I did my tuning with the cowl off, then really don't need to touch them after it's set up right on a gasser. Good luck with your install. The power onthis frame was very much worth the effort!
