Aeroworks Retracts
VA
Aeroworks Retracts
Rocco or Kevin, I am having trouble with air leaks in the air cylinders where the oring is supposed to seal under pressure. I have injected high air tool oil in all the lines and cylinders and only have leaks around the cylinders for the retracts. Have talked with Mark and asked if there were replacement orings and the response was to go to Auto Parts store and fins an oring. The problem with that solution is all the orings offered are 1/16 wide. this is to thick because under 80lbs pressure they blow out the side. Please help with my problem. Rick
