Loose aileron hinge
OR
Loose aileron hinge
A just did a thorough review of the condition of my AW YAK 54 50cc after 75 flights. It is holding up well, but I did find that an outer aileron hinge has completely detached itself from the wing. I can move it up and down 1/16 of an inch by flexing the aileron. The aileron side of the hinge is fine. Does someone have an idea how to fix it?
BTW...many have stated in this forum that the landing gear breaks loose over time. After about 100 landings, my gear plate is rock solid. The plane is easy to land in anything up to 20 to 25 mph. I did dork one landing in high winds, but the damage was minimal.
NJ
RE: Loose aileron hinge
Dab a little Vaseline on the hinge joint and shove some gorilla glue into the gap on the wing side. Spray a little water on it before putting it in while on the tooth pick. You don’t need much to activate it. Keep the wing flat, only lifting to wipe the seeping glue. The glue expands and should fix you up.
OR
ORIGINAL: gregg660
Hey guys....
At the end of last year I had two flights with some flutter and I believe it was on the ailerons. I'm getting things ready for after the darn snow melts in upstate NY, and upon close inspection I can see very slight movement in and out on several of the hinge points.
Two options:
1. I picked up here on RCU that some guys cut the hinge at the joint and then melt the points out with a hot soldering iron. Then they clean the hole with a piece of sharpened brass tubing; replace the hinge.
2. Rather than do that, I have an idea to inject some gorilla glue at/near the end point of the hinge and let the glue expand toward the hinge joint. I work in healthcare and have some 20 gauge needles that I want to try; too bad I can't xray the wing! So I'm hoping someone has had the covering off an Aeroworks 50cc Extra 260 and can tell me what is in there by the hinges before I start putting holes in the covering.
Is the control surface side just soft balsa stock? Does the trailing edge side of the wing, stab and fin have blocking? What can you tell me in this regard?
Also, any other ideas are welcome too.
Thanks in advance for the help guys!
Tom
Two options:
Tom
ORIGINAL: tomfiorentino
Hey guys....
Two options:
Tom
Hey guys....
Two options:
Tom
Is your plan to peel back the covering and expose the hinge point inside the wing? Then put the GG on the point nextto the wood? That plan should be fine.
I thought that maybe the needle could be jabbed into the wood from beneath, right on the hinge point, and GG injected. It might be less work. You will know when you hit the plastic part
ORIGINAL: MTK
Tom,
Hey guys....
Two options:
Tom
Hey guys....
Two options:
Tom
Thanks for the response...
Yes, I want to avoid peeling covering so I'm thinking, like you, about jabbing through the covering. I'm not sure if Aeroworks used a block behind the hinge-point for additional gluing surface. I made a little diagram. Not a huge deal, but I'm just thinking the needle goes in a different spot depending on the presence of a block.
Please see attached!
Thanks again,
Tom
