Aeroworks 40% G-202 CG
Hi all...
I have an older Aeroworks 40% G-202 that I'm trying to find out what the recommended CG is.... anyone happen to know?
It flies OK, but seems a little on the tail heavy side to me.
My Feedback: (29)
To check the CG pull up to a 45 degree up line, roll inverted and ease off the sticks. If it holds the line or steepens the climb then yes you are tail heavy. Always suggest taking a previously built airplane or even an ARF and measure it out so you know where the thrust angles and incidences are before flying. Make changes if needed.
