Aero-Works Stingray
Aero-Works Stingray
New Aero-Works Stingray small electric pattern aircraft. Perfect for practising pattern or IMAC when you can't make it to the field.
Check it out at http://www.aero-works.net/store/detail.aspx?ID=256
Here are the specs
SPECIFICATIONS
Wing Span 39"
Wing Area 321 Sq. In.
Length 37.25"
Weight 25 TO 28 Ounces
Motor 200 to 300 Watt
Radio 4 Channels minimum
Here are the specs
SPECIFICATIONS
Wing Span 39"
Length 37.25"
RE: Aero-Works Stingray
Mark,
I have been looking real hard at the Stingray and have a couple quick questions. I have an Eflite 480/1020 outrunner with a couple Lipower 2100's needing a home. Is this enough for the StingRay? Definitely looking to do pattern/precision flying no 3D. How is the cooling for the motor? I checked ou the manual and is doesn't look as if much air can get it.
Thanks for your help,
dawg
dawg
