Aero Works P-51?
I was waiting to see who would catch that.
I did have an air leak after completing the Mustang. However, I found that it was temperature related. I keep my shop heat at 55 to 60 degrees when I'm not working on anything. My air leak was happening when the gear was in the up position. What I found out was that after having my shop heat at 70 to 75 degrees for all day on a weekend, the air leak was gone and has not happened again. Also, I believe I read on this thread that someone mentioned that sometimes the gear on any retract airplane may have to be cycled quite a few times to seat the o rings on the airvalves. You may even consider putting some heat via a heat gun to the airvalve to help the o rings to seat properly. I am getting 4 complete gear cycles with a starting pressure of 110 psi with a single airtank. Some of the other guys on this thread have said they are going to an extra air tank for insurance. This is my first retract aircraft and in my mind all I need is for the gear to go up once and down once each flight, so with 4 cycles available, I'm thinking I'm ok. Liked the AW Mustang so much am starting a second one this weekend. Going to have to join AW anonymous pretty soon.
flstn95
Thanks for the quick reply and the comment about the AW anonymous problem is pretty funny
Later and I'll let you know how the change in temp helps and I'll just keep cycling things to see if it helps seat things in as well.
I too had the valves leak, tried the extra O-rings AW includes, but it didn't help, so I ended up replacing the valves. I still have a leak somewhere only when the gear are down. I've tried and tried to find it but can't. Might be in the cylinder itself, not sure. Worst part is, when I check it in the garage, they hold air up and down no problem! Get out to the field - leak. I got a little frustrated, so just left it alone for a few days, I've been working 12 hours days anyway. I also ordered and received a gear failsafe from TamJets that I'm going to install just for some extra insurance. Other than that everything is fine. This plane flies so nice it almost relaxing to buzz around the sky. I am probably going to give Mark at AW a call to order a extra left or right gear just to have some parts and try a different cylinder see if that solves the leaking.
I know that the AW P-51D uses a different air system other then theRobart systembut your leaking air valve might be fixed the same way I did witha very leakyRobart air valve on my giantTopflite P-51D. I used air tool lube oil to solve the leaking valve problem. I disconnected the quick disconnects on the retract and down lines and added several drops of the lube oil into each line, repressurized the air system to 100psi and cycled the gear several times until the air pressure dropped to the point where the gear would not cycle any more. I re-pressurized the systemto 100psi and cycled the gear again until the pressure droppedbelowcycling pressure. I re-pressurized the system again to 100psi and left the system alone for 4hrs. When I rechecked the air pressure after 4hrs it read 95psi, leak fixed and I have not had a leaky valve since. The lube oil lubricates the o-rings and allows them to seat properly. Hopefully this technique will work for those who try it? It’s a lot cheaper adding the lube oil compared to buying a new air valve.
Roger
1. Tail wheel doors need to be connected
2. Keleo Exhaust installed (not received yet)
3. Decals from Pro Mark (not received yet)
When I hooked up the retracts I found leaks around the system. I injected some air tool oil into the system to seat all the O rings. It worked perfect. At 110 lbs pressure I get 5 full retract cycles without a glitch. I made a video to show how well the system works. On the 5th retract cycle I am at 60 lbs pressure at it still works.
I re-pressurized the system to 110 lbs and let it sit for 15 minutes and re-checked to find out I had 98 lbs pressure remaining. After the oil was distributed throughout the system and a little (not much) adjustment to the retract servos I had this thing working like a charm.
Check out the video located at http://www.youtube.com/watch?v=2d1GbYiDWjEto see 5 full cycles at 110 lbs.
I LOVE THIS BIRD MANG.
Rick
Brian
Nick
Nick - Thanks for that catch. I had one other question. I was fooling around with the new Robart air tank and went to stick my fingers underneath the servo/air valve plate and felt the bottom of the servos almost resting on top of the gas tank. Now I don't have the tank in yet so it wasn't setting on the foam. When the tank is filled and 'hanging' in actual flight I'm wondering if it'll hang enough to actually rub the servo bottoms. I plan on putting some 3/8'' ply shims on each side of the current rails to raise it a tad if needed. Just another observation.........
Just give me a little space and once and awhile this ol'brain will hiccup and do a re-start and I'm on the right path again
efly26 - I'm afraid I checked out what you commented on above and mine all matches up almost perfectly.
Nick
Just saw your post about your issues with the P-51. Give us a call so we can discuss I want to make certain you are happy and we don’t have problems with future productions.
Please ask for Rocco or Kim, Thanks!
Thank You
Rocco
Aeroworks
303-371-4222
Nick
the production models have the resistor built into the gear sequencer. I have not range checked mine yet, but everything works fine in the shop. I am new to 2.4 and the thing I wonder about is my receiver is mounted next to the air tank and the servo leads and various wiring aare very close and in some cases right on top of the receiver. Fellow modelers say that it will not bother the 2.4 systems. Anyone out there who agrees or disagrees?
flstn95
Efly,
flstn95
I too am running 2.4 in my P-51. I'm using JR's 1221 receiver with the 3 satellite receivers. The main receiver is in the location shown in the instructions, one on the "floor" just inside the scoop at the bottom of the fuselage, one on the right side of the fuse near the tail wheel, and the 3rd one on the left side of the fuse just under where the wing mounting bolt pads are. Mine range check fine, no glitches. I usually use the flight logger for the first couple of flights to see if the receivers are in good locations. JR says that it's normal to have 50 - 100 fades per flight on any one of the receivers, but I only got about 10 - 12, so I guess placement was fine. My plane came with an addendum to the instructions stating the same thing flstn95 said about the resistor built in to the sequencer and as such, I didn't use it. I too have the ignition module for the DA up front mounted on the engine box. Sorry you are having so much trouble with the plane, even with the cost, I'm very happy with mine. Flew her today and everytime I take it up, just about everyone stops to watch (talk about nerve racking!!!!). I think I need to move the CG a little more forward. I balanced it just a hair aft of the recommended point, but the elevator is very sensitive. I can look around and see if I kept the resistor and send it to you if you'd like to give it a try, but I think I tossed it.
