ACE RC Whizard 1/2A Model Airplane, Built Up Balsa Wing, ARC
ACE RC Whizard 1/2A Model Airplane, Built Up Balsa Wing, ARC. Everything needed to complete plane is included. The wing span is currently 44" as I was making an oversized wing. Stock wing is 40-3/4" long so you can keep wing as is or cut off a 2" bay on each side and add wing tips.
Plane was built for two, aileron and elevator, instead of the usual elevator, rudder, and is to be powered by a Cox Medallion or TD .049. Trailing edge stock, wing tip blocks, linkages, hinges, control horns, clevises,extra balsa sheets...everything necessary to complete plane plus building plans are included.
Fuselage and wing are built straight, strong and light. The fuselage and tail feathers are complete and ready to cover. The wing will need the trailing edge and ailerons installed and a servo mount added to the wing. This was not previously done as the buyer needs to decide if the they want the added length on the wing or cut off one bay on each side and add the wing tips for the stock wing span.
Specs:
WS: 40-3/4"...currently 44"
Length: 30"
Weight: Fuse & Wing as shown, 9 ounces total(not including traling edge stock, horizontal and verticle stabs).
$119.00
Specs:
Length: 30"
$119.00
