Variable Pitch Prop
RE: Variable Pitch Prop
Yes, I have seen ( here in rcuniverse) pictures of a variable pitcht 3-blade prop on a 100" wingspan turboprop Tucano build by someone in Austria. You should search for tucano, or turboprop or even variable pitch. Sorry for not being more specific. Good luck.
geared
geared
My Feedback: (12)
There is a place that makes a prop that the pitch may be changed however it must be done while not in motion. I believe it would require some sort of hyraulic pressure to change the pitch when airborne.
ND
ON, CANADA
http://www.jakadofsky.com/htm_en/welcome.htm
Solo props also makes an ground adjustable prop.
http://www.soloprops.com/index.html
Grinder.
Grinder.
Not bad.
Don't really fancy the helicopter setup ..... might get really flimsy at higher revs right?
But I do like adjusting the pitch on the fly.
Wonder if there are ready made systems that we could buy.
