Airtronics Support Forum Ask any questions you may have about Airtronics radios and product here and get answers direct from the Airtronics Team.
Analog retract servo
Reply
Old 12-25-2010, 06:23 PM
tankey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Analog retract servo
Hi, am gearing up a large scale glider using the 10ch rx and have read that some analog servos are incompatible anyone know if the JR retract servos are ok to use? Tankey
tankey is offline
Old 03-12-2011, 07:46 AM
coupar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Analog retract servo
Do a search on 791 and you will see a lot about a 6v problem and resolutions.
I'm using a JR 791. These servos have a problem, if you run them on 6V. The input signal voltage level which the newer receivers in general output doesnt trigger the servo. - ~2.5v input signal level,while the old receivers were typically over 4V level. There are a couple of ways round this. Either run the servo with 4.8V or buffer the receiver signal level to boost it.
I used a booster for my 791 and it runs fine using 6v with Airtronics receiver.
coupar is offline
Old 03-15-2011, 10:29 AM
I ALSO FLY RC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Most Analog proportional servos cannot keep up with the fast data rate of the SD-10G. However, the JR 791 is just a switcher type servo, and it is not proportional. It operates by a change in pulse width, e.g., wide to narrow for one direction of rotation and narrow to wide for the other direction; therefore, you should not have a problem.
Airtronics Technical Support
800-262-1178
I ALSO FLY RC is offline
Contact Us Archive Advertising Cookie Policy
