Airtronics Support Forum Ask any questions you may have about Airtronics radios and product here and get answers direct from the Airtronics Team.
Smoke Switch Question
Reply
Old 12-28-2010, 11:48 AM
skysfallin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Smoke Switch Question
Hi Mike. I am trying to assign a switch to power up the smoke pump on a new Yak I am putting together. I am running the SD10G transmitter and reciever into a Power Expander Sport. I have channel #5 open on the reciever and the Expander. The smoke pump is a slimline unit with a power cord to the battery and a tie into the throttle servo with a Y harness to modulate the quantity of smoke being pumped. The smoke pump is rated to pull 240mah when running. My question is how to get the channel assigned to the gear switch so I can power the pump on and off using the gear switch to do it.
skysfallin is offline
Old 12-28-2010, 11:51 AM
MikeGreenshields
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Smoke Switch Question
Go to the switch assign menu, go to gear channel five if that's the channel you want to use, and then assign the switch positions you want to use for the switch to be on.
MikeGreenshields is offline
Reply
Display Modes
