What happened to the Futaba module?
RE: What happened to the Futaba module?
It has been delayed. Sanwa engineers found something in the pc board they wanted changed. I'm expecting revised samples soon and assuming testing goes as well as it did on our first sample, we'll go straight into production.
Note this is an FH1 system thath will have about a 1.5 mile range and will work on all of our FH1 receivers including the 3gram indoor receiver and the RX500 full range 5channel receiver.
It will come with a 7 channel full range receiver that has a modified case so that regular FutabaJ plugs will plug straight in.
Mike
Mike
