Airtronics Support Forum Ask any questions you may have about Airtronics radios and product here and get answers direct from the Airtronics Team.
Dual Servo Flap throw
Reply
Old 03-20-2011, 04:30 PM
Hughes500E
Hughes500E's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Dual Servo Flap throw
I must be missing something, setting up an aircraft with 2 flap servos (set in TYPE as such) and assigned to a VR switch (5), I cannot increase the amount of throw for my needs. The pre-programming must be limited to about a 40 degree max throw or I am missing something?
C-Mix is an option of course but I am curious!
Steve
Hughes500E is offline
Old 03-21-2011, 07:50 AM
ToddNicholson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Dual Servo Flap throw
Hi Steve,
A couple of things. In order for VR5 to have control over the Flaps, the Flap Switch must be in the Flap1 position. VR5 will then proportionally control the Flaps from 0 degrees to maximum deflection determined by the EPA percentage value you've programmed for LF (Left Flap) and RF (Right Flap) in the SURFACE menu. To adjust how far each flap deflects, adjust the RF and LF Flap1 EPA percentage value in the SURFACE menu. Keep in mind that EPA values that exceed the LIMIT values for that channel will not be reflected on your model because EPA can never exceed the LIMIT. So, if your LIMITS for LF and RF are 100%, but you need more throw, first set the LIMITS to 150% (or whatever you desired), then adjust the EPA to match. Please note that to adjust FLAP1 EPA, the Flap switch must first be in the FLAP1 position. The SURFACE menu will display N,1 or 2 next to the LF and RF entries based on the position the Flap switch is in.
I hope this helps.
Regards,
Todd
Team Airtronics
ToddNicholson is offline
Old 03-21-2011, 08:50 AM
Hughes500E
Hughes500E's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Todd,
Type includes two flap servos. I have set the switch assignment for flap 1 to ON flap 2 is - VR assignment Flap 1 is assigned to VR5. Limits are set to 150 respectively. EPA allows for max 40 degree throws.
Are you telling me that I have to assign Flap1 to toggle and assign VR5 to flap 1 to obtain more throw? I guess it would help from accidently turning flaps on etc... I'll try it!
Old 03-21-2011, 11:33 AM
Hughes500E
Hughes500E's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Didn't make a difference. Whether I assign Flap 1 to a toggle or just turn it on and assign it to the VR5, the EPA just shifts the 40 degree throws on LF and RF in surface as if they were sub trims.
Old 03-22-2011, 09:30 AM
Hughes500E
Hughes500E's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
With thanks to Jack of the Airtronics tech support, I have what I need.
Old 03-22-2011, 12:18 PM
MikeRuth
MikeRuth's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Hughes500E
Can you eleborate on what was changed?
MIke R
MikeRuth is offline
Old 03-22-2011, 10:50 PM
Hughes500E
Hughes500E's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
We set up compensation mixes and assigned them to VR5 giving me more than enough throw.
Old 03-23-2011, 06:37 AM
MikeRuth
MikeRuth's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
MIke R
MikeRuth is offline
Reply
Display Modes
