Airtronics Support Forum Ask any questions you may have about Airtronics radios and product here and get answers direct from the Airtronics Team.
Flap on throttle stick
Old 05-09-2011, 02:46 PM
tankey
Default Flap on throttle stick
I like to have my flap set up on the throttle stick and switch to crow for landing (gliders) is there a way o do this with the SD10....Tankey
Old 05-17-2011, 08:17 AM
MikeRuth
MikeRuth's Avatar
Default RE: Flap on throttle stick
This is done with the Glider template and practicly already setup for you.
Just load the glider template and try it.
MIke R
Old 06-14-2011, 03:32 PM
tankey
Where do I find this template?
Old 06-14-2011, 03:53 PM
MikeRuth
MikeRuth's Avatar
I going to assune you are new to full house gliders and programming any radio based on your questions.
Start out by reviewing the radio manual. It is one of the best. Then begin on pg 25 learning how to sekect a model type. Such as a glider. Then pg 125 for sail plane specufic guidance.
Give it a whirl and expetiment.
Then I and others can help with dialing it in.
Mike R
Oh and specificly under the SYSTEM MENU.
ORIGINAL: tankey
