Airtronics Support Forum Ask any questions you may have about Airtronics radios and product here and get answers direct from the Airtronics Team.
Dual flap servos on a 6G system
Reply
Old 09-25-2011, 03:24 PM
DennisD
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Dual flap servos on a 6G system
Is it possible to set up the 6G for dual flap servos without using a reversing Y cable?
Any assistance would be appreciated.
Regards,
Dennis
DennisD is offline
Old 09-26-2011, 02:03 PM
I ALSO FLY RC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Dual flap servos on a 6G system
Dennis:
Normally, you will only have one Flap channel on the SD-6G, so you will have to use a "Y" harness on Channel #6 to operate both Flap Servos. If you select 2 Aileron servos in the TYPE menu, your channel outputs are #1 Elevator, #2 Left Aileron, #3 Throttle, #4 Ruder, #5 Right Aileron, #5 Flap. However if you select only 1 Aileron in the TYPE menu, you will have to use a "Y" harness on the Ailerons, and you could then mix Channel #6 FL to Channel #5 GE to obtain dual Flap servos, but you may not want to do that. If you did, you would set the Gear EPA to 0% for both positions of the Gear Switch and adjust the Hi mixing Rate in C-MIX 1 to obtain the correct deflection of the second Flap servo when the Flap switch is operated....... It all comes down to the fact that for a model with Elevator, dual Ailerons, Rudder, Throttle, you only have one Flap channel.
If you have any questions or if I can assist you further please call or send an E-mail
AIRTRONICS TECHNICAL SUPPORT
800-262-1178
rc1pilot@jcis.net
I ALSO FLY RC is offline
