Airtronics Support Forum Ask any questions you may have about Airtronics radios and product here and get answers direct from the Airtronics Team.
Program SD-10G stopwatch
Reply
Old 02-24-2013, 10:28 AM
Bidwin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Program SD-10G stopwatch
Just bought an SD-10G that's going into my first electric plane. I want to use the radio's stopwatch as a flight timer by turning the stopwatch on when the throttle stick is advanced from no/low throttle then turning it off when the throttle is at or near 0 (or -100%?). I've assigned the stopwatch to the throttle stick but can't get it to stop when I move the stick to 0. If I set Start and Stop to the throttle stick the stopwatch starts then stops each time I advance the stick from 0. Not good for using the stopwatch as a flight timer! Is there any way to do what I want to do??
Bidwin
Bidwin is offline
Old 02-24-2013, 10:39 AM
aydin3
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Program SD-10G stopwatch
ORIGINAL: Bidwin
Bidwin
What I have done is to set the on function to start the switch on S1, and the off function on S2.
stick switch 1
stick > TH
Point> -95%
ON>H
Sound>ON>OFF
Stick Switch 2
STick>TH
Point> -98%
ON>L
Sound?OFF>ON
That way if you close the throttle in flight the timer stops (as batery is not being used that much)so you get a better feel for what is left.
One other thing I do for my electric models is to set a throttle off switch ie an arming switch. I use Switch 22/23/24 for this :
TH-CUT>22 or 23 so only when in position 24 is the throttle live.
Hope that helps.
Dave L
aydin3 is offline
Old 02-24-2013, 10:41 AM
aydin3
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
opps.,..one other thing I have set it the sw Assign
START>S1 AND24 so it will only start when the Throttle is armed
STOP>S2 OR23 so that cutting the throttle off completely stops the timer.
Hope that helps.
aydin3 is offline
Old 02-25-2013, 05:18 AM
Pippin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www.hobbypeople.net/media/upl...tups_Guide.pdf
Pippin is offline
Old 02-25-2013, 09:29 PM
Bidwin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave L,
Thanks much for the informative response. Your timer setup is what I was looking for, and I appreciate your adding the throttle cut feature. Weather just turned cold and rainy again, so looks like I'll have to wait another week or so to try your solutions real time.
Pippin,
Thanks for the link. I stumbled across it after reading another thread. Didn't see the second timer section, though, until today. Similar to Dave L's solution.
Bidwin
Bidwin is offline
Contact Us Archive Advertising Cookie Policy
