*92824 Receiver & HV Servos*
My Feedback: (10)
I fly giant scale and I've been running Airtronics since the 80"s and currently use the SD-10G TX. I am using the 92824 8ch receivers. My question is about all the newer HV servos and how it effects the 92824 receiver. I have been having trouble with glitches on my elevator and rudder servos and if there is any kind of issue when using 48"-52" long extensions and power getting from the receive back to the servos in the rear of the plane. I am running servos that are 350-450oz/in. of torque. I also use 20 AWG Servo Extensions of good quality. I normally run 1 antenna straight towards the rear of the plane and the other down towards the bottom of the plane or towards the side of the plane. I run both antenna's inside a plastic nyrod. This issue is happening on 2 of my 5 giant scale planes and have yet to figure out what is causing it. Any help would be appreciated.
