*Airtronics RD8000 2.4 GHz*
#251
RE: *Airtronics RD8000 2.4 GHz*
If you like the machined, anodized sticks, they are available separately in different colors. So, not only can you change the ends if you prefer, but you can even get different colors!
The RDS8000 as is wil come with the sticks as shown in the pictures.
Mike
Mike
#252
FL
I've been sitting back reading this post since it began and contemplating whether I should pull the trigger. Finally got the best of me so I've told Tower to send me a tranmitter and 3 additional receivers... I'm sure I'll order some more receivers later to convert majority of my hanger, but this is enough to get me started...
My brother has all Airtronics gear and always speaks highly of them. Among other things, I like the fact that the LCD screen is above the joysticks. Maybe it makes the case a little taller but I would guess it's a little easier to glance at while you're flying (if you have to...).
Ditto on comments about Mike being up front and informative at all times. You've got a loyal fan base
A future Airtronics Convert...JLS
#253
My Feedback: (25)
Not sure where you saw that price. They are $79.99 on Tower Hobbies site:
http://www3.towerhobbies.com/cgi-bin/wti0050p
#254
ORIGINAL: sailr
See also post #241
#258
UT
Can someone post a pic of how the radio balances with the neck-strap installed?
It seems to me that this radio wouldn't be as far off balance as others, because the screen is located above the sticks. Just wondering.
LT
LT
#260
GA
Thanks Mike, So far I haven't needed ModelMatch or ServoSync. I don't think I'll need it in the future. Sounds like a good idea, but I am fairly confident that is why the model selected is displayed on the LCD(imagine that). Thanks Skip D
#261
The radio hangs "bottom" low about 10-15 degrees. If you want it to hang level, we will move the mount for you and will not charge you to do so (although you'll have to ship it to us). Moving the mount is fairly easy although the tech has to do it becuase there are 4 pc boards that have to be removed to access it. Our tech can do it in about 5 minutes. But if you're not familiar with the wiring, etc you can destroy the radio!
I find the angle it hangs at is perfect for me.
Mike
Mike
#263
CA
Went out for a quick fly today with the radio in both my GP yak (Moki 2.10 power not gas) and my Golden Eagle FP-1 (moki 2.10 power not gas). First off let me say that I have been flying with the RD8000 for several years now and you will be happy to know that after setting up the new radio with the same trims and specs that I had saved in my old 72 band radio the new radio did not need any new trims upon take off. Everything transfered over exactly as I had had it before. Also let me add the this radio works PERFECTLY!!!. Reaction time on the sticks the servo movement seems a hair quicker but it never really was that slow on the other radio. The radio feels very light and balanced while flying ( I do not use a neck strap). Not one issue to report. Ground range check was far better than my old radio. Also did a test putting the plane behind a chain link fence and walked away about 150'+ still had perfect response on all surfaces ( motor was running at the time of test). Great job Mike and Airtronics it was worth the wait..Now I just need about 10 more recivers. ....Happy flying
#264
GA
Well, it appears as though my RDS might not ship this week. Hobby Club isn't very imformative. Hopefully find something out today. Much much much sorrow. I am happy to hear about yours Gotsky. So it does appear faster than your RD? Sounds like the RDS is going to be worth the wait. (2 months so far) Also do I understand there is no rachet on the throttle? Thanks and I wish you continued good luck. Skip D
#265
CA
Yes it seems a little faster in response time, but I have no real way to test.. The rachet on the throttle is there but it is very smooth and/or subtle. I'd say perfect is a good word to describe it.. So far so good..
#266
GA
HU HU!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!! I got an e-mail from Hobby Club today and they said my RDS and 3 RXs will ship out today. It's been a long wait but sounds like it'll be worth it. As soon as I get it flying I'll fill you guys in. Later on Skip D
#270
ORIGINAL: aeajr
As I understand it the software and other features of the radio are the same as the 72 MHz version RD 8000, correct? Or does 2.4 GHz bring some new features to the radio?
That is too bad as expo/DR for rudder is missing from the RD and RDS and that is very important for the 3D guys......
But as a LONG TIME user of the RD8000 it sure did most everything else I needed. Trim step especially. I shed a tear when I left Airtronics and went to Spektrum, but really miss Trim Step on the DX7. Enough to make me consider the x9303.
What I really like that I want to see in all new 7-8ch mid range systems are:
1 - Sliders (Optic 6 has this...)
2 - Timer able to start with throttle stick (7C FASST offers this...)
3 - A sub $50 receiver option for use in our parkie type airplanes
Mike
#271
ORIGINAL: pda4you
No new features - Mike points that out somewhere in this thread....
Mike
ORIGINAL: aeajr
Mike
#272
Is the RDS8000 able to start a timer with the throttle stick or assigned it to a 2-3 pos triggle switch?
The lack of this made me dumbed the 9X2.
David
David
#273
UT
ORIGINAL: aeajr
As I recall, the RD8000 has a number of user mixes. I would expect you could use this to create a DR for the rudder. I know the DX6 guys were doing that.
David
David
LT
#274
Dual Rate on RD8000 is no problem .
You should mix ruuder --> rudder on 50% on one of the c-mix swithes.
Just set the value you want for the low rates .
Works great .
No expo on plane mode .
orginallly posted by igalr
Works great .
#275
CA
Not to worry, I am anxiously awaiting my RDS8000 that is already on order. One question though. Will there be additional receivers available? I see JR/Spektrum has a handful of them now, including one that appears to be the size of a postage stamp. I don't fly the little foamies, but will buy one sooner or later. Knowing a smaller receiver was in the works down the pipeline would be nice to know.
Thanks-
Thanks-
